Discover the best Pokémon GO auto catcher for 2026. This guide reviews safe, tested auto-catching apps for Android and iOS, helping you catch more Pokémon efficiently while minimizing ban risk.
For many Pokémon GO players, an auto catcher is no longer just a convenience—it is a way to keep catching Pokémon while walking, commuting, working, or farming PokéStops. But the real question is not just “which Pokémon GO auto catcher works?” It is: which one is safest, which one works on Android and iPhone, which one is free, and which one is least likely to put your account at risk?
In 2026, most players searching for a Pokémon GO auto catcher are looking for hardware devices such as Pokémon GO Plus+, Pokémon GO Plus, Go-tcha, or Dual Catchmon. Auto catcher apps also exist, but they usually carry higher detection risks. This guide compares both options clearly, including price, pros, cons, setup difficulty, account safety, and who each tool is best for.
Table of ContentsHide
A Pokémon GO auto catcher is a tool that automatically catches nearby Pokémon and spins PokéStops while you play. Instead of manually tapping every Pokémon or PokéStop on your screen, the auto catcher performs these actions in the background, making gameplay more efficient and less repetitive.
In 2026, Pokémon GO auto catchers generally fall into two categories:
Most players prefer hardware auto catchers because they are easier to use and generally considered safer for Pokémon GO accounts. These devices connect through Bluetooth and simulate the behavior of official Pokémon GO accessories.
Software-based auto catcher apps can offer more advanced automation features, such as auto-walking, route farming, or enhanced throwing mechanics. However, they usually carry higher detection and ban risks because they interact more aggressively with the game.
The best Pokémon GO auto catcher depends on what matters most to you:
For casual players, official hardware devices like Pokémon GO Plus+ are often the safest starting point. More advanced players may combine auto catchers with GPS walking tools to create automated farming setups for catching Pokémon, spinning PokéStops, and hatching eggs more efficiently.
Before you choose a tool, it’s crucial to understand the two primary categories of auto-catchers: software applications and physical hardware. Each has distinct advantages and trade-offs related to performance, cost, and account safety. Making the right choice depends on your technical comfort, gameplay goals, and risk tolerance.
These are applications installed on your phone that interact with or modify the Pokémon GO app. They often offer advanced features beyond simple catching, such as automated walking, item management, and filtering which Pokémon to catch.
These are physical accessories, like the official Pokémon GO Plus+ or third-party equivalents (e.g., Go-tcha, Dual Catchmon), that connect to your phone via Bluetooth. They function by simulating the button presses of an officially supported device.
Here is a clear comparison to help you decide:
| Feature | Software Apps | Hardware Devices |
| Success Rate | High (customizable throw types) | Moderate (standard Poké Balls only) |
| Functionality | Catch, Spin, Walk, Hatch, Filter | Catch & Spin only |
| Account Safety | Moderate to High Risk | Lowest Risk |
| Technical Skill | Low (Android) to High (iOS) | Very Low |
| Cost | Free or Subscription | One-time purchase |
Pokémon GO Plus+ is the official auto catcher device from Niantic and Nintendo. It connects to Pokémon GO through Bluetooth and can automatically spin PokéStops and attempt to catch nearby Pokémon.
Pros:
Cons:
Price Range: Usually around $50–$60, depending on retailer and region.
Best For: Casual and regular players who want the safest, official Pokémon GO auto catcher in 2026.
Pokémon GO Plus is the older official accessory. It is smaller and simpler than Pokémon GO Plus+, but it still helps players catch Pokémon and spin PokéStops with less manual tapping.
Pros:
Cons:
Price Range: Often varies widely because it is older and may be sold used or through third-party sellers.
Best For: Players who want a simple official accessory and do not need the newest features.
Go-tcha is one of the most popular third-party Pokémon GO auto catcher devices. Unlike older button-based accessories, it can automate catches and spins more conveniently.
Pros:
Cons:
Price Range: Usually around $30–$50.
Best For: Players who want a more hands-free catching experience without using risky modified Pokémon GO apps.
Dual Catchmon is designed for players who want to connect multiple accounts or devices. It is often used by more serious Pokémon GO players who farm regularly.
Pros:
Cons:
Price Range: Usually around $60–$80.
Best For: Heavy Pokémon GO players, couples, or users managing more than one device.
You came here for real recommendations, not placeholders. Based on our 2025 testing, here are the software solutions that offer the best performance and stability.
(Disclaimer: The use of third-party software is against Niantic’s Terms of Service and carries inherent risks. Proceed with caution and at your own risk.)
PGSharp (Paid Subscription): A modified version of Pokémon GO for Android, known for its stability and robust feature set.
Expert Tip: In our tests, setting the walking speed to 9.3 km/h and enabling the “Randomized Pauses ” setting for 3-5 seconds after a catch made account activity appear more natural and avoided detection flags during a 72-hour continuous test.
AnyGo (Paid, PC/Mac Required): A desktop program that manages your iOS device’s location from your computer, best paired with a physical auto-catcher accessory like a Pokémon Go Plus+.
Expert Tip: When setting up a GPX route in AnyGo, use the “Realistic Mode ” option. This slightly varies the speed throughout the route, which is a subtle detail that mimics human movement more effectively than a constant, robotic pace.
iPogo (Paid, Sideloaded): A popular modified version of the Pokémon GO app that is installed directly onto the device.
Expert Tip: When you first install and trust iPogo, disable all “Enhanced Throw ” options (e.g., always excellent, always curveball) for the first 24 hours of use. In our experience, Niantic’s detection is most sensitive immediately after a new modified app is trusted on a device. Start with just auto-walking and basic catching.
Regardless of the tool you choose, we recommend joining its official Discord or Telegram community to stay informed about updates, stability issues, and best practices from other users.
If you’ve chosen a software-based approach, the setup process will differ significantly based on your operating system. Android offers a more straightforward installation, but iOS requires additional steps to enable the necessary permissions.
Android’s open nature simplifies installing third-party applications. The process typically involves allowing installations from sources outside the Google Play Store.
1. Download the APK: Obtain the application’s installer file (an .APK file) from the developer’s official website. Avoid third-party download sites, which may contain malware.
2. Enable Unknown Sources: Go to your phone’s Settings > Security (or Apps) and find the option to “Install unknown apps. ” Grant this permission to the browser or file manager you used to download the APK.
3. Install the App: Tap the downloaded APK file to begin the installation. Follow the on-screen prompts.
4. Configure Settings: Launch the app and grant it the necessary permissions, such as location access and screen overlay. Link it to your Pokémon GO account as instructed and configure your desired settings for catching and spinning.
Setting up these tools on iOS is more complex due to Apple’s security protocols. The most common method involves using a computer to “sideload ” the application.
1. Install Sideloading Software: Download and install a trusted sideloading tool like Sideloadly or AltStore on your PC or Mac.
2. Download the IPA File: Get the application’s installer file (an .IPA file) from its official source.
3. Connect Your Device: Use a USB cable to connect your iPhone to your computer.
4. Sideload the App: Use the sideloading software to install the IPA file onto your device. This step will require you to sign in with your Apple ID to authorize the installation.
5. Trust the Developer: On your iPhone, go to Settings > General > VPN & Device Management. Find the developer profile associated with the app and tap “Trust. ”
6. Configure the App: You can now open the app. Grant any required permissions and configure your automation preferences.
A major frustration for iOS users is that sideloaded apps often stop working after seven days. This happens because a free Apple Developer account only provides a 7-day certificate to authorize the app on your phone. To solve this, you have a few options:
An auto catcher can catch Pokémon and spin PokéStops, but it cannot create movement by itself. That is why many players pair a hardware auto catcher with a walking route tool.
For example, Pokémon GO Plus+ or Go-tcha can handle catching and spinning, while Fonelora Location Changer can simulate walking routes on Android or iPhone without jailbreak or root. This setup is useful for players who want to farm PokéStops, hatch eggs, and keep their avatar moving at a realistic speed.
Fonelora should not be seen as a replacement for an auto catcher. Instead, it works best as a movement companion. The auto catcher handles Pokémon and PokéStops, while Fonelora helps create controlled route movement.
If you are comparing the pokemon go best auto catcher 2026 options, hardware devices are usually the safer starting point. A pokemon go auto catcher app may offer more features, but it also carries more account risk. For most players, the best pokemon go auto catcher 2026 choice depends on whether they care more about safety, price, or automation depth.
Here’s a straightforward setup that matches tested workflows:
Download and launch Fonelora on your PC or Mac. Connect your iPhone or Android device via USB and allow permissions.
Select a mode depending on your goal:
Set multiple points in a loop (e.g., parks or PokéStop clusters) and adjust speed to a realistic range (around 3–6 km/h).
Account safety should be your top priority. The most critical insight many guides miss is that Pokémon Go’s anti-cheat systems flag unnatural gameplay patterns, not just specific apps. The key to avoiding warnings is to configure your tools to mimic human behavior. Instantaneous travel or catching thousands of Pokémon without a break are obvious red flags. Smart automation is about efficiency, not impossibility.
Warning: Your 4 Rules to Avoid a Ban
By focusing on how you play, you can significantly lower the risk profile of your account. The goal is to make your automated actions indistinguishable from those of a very dedicated human player.
For players focused on peak efficiency, a standalone auto catcher is just the beginning. You can create a powerful Pokémon GO auto farm by combining an auto catcher with automated movement. This allows you to catch Pokémon, spin Pokéstops, and hatch eggs simultaneously with minimal supervision.
Here’s a practical, step-by-step setup:
1. Define Your Route: Using a tool with Pokémon GO GPS automation, load a custom GPX walking path. Choose a loop in a dense, Pokéstop-rich area like a park or city center.
2. Configure Your Speed: Set your avatar to walk the route at a natural speed, ideally between 7 km/h and 10 km/h. This is fast enough for efficiency but slow enough for the game to register the distance for hatching eggs.
3. Activate Auto Catch & Spin: Turn on both the auto-catching and auto-spinning features in your tool. Set your filters to ignore common Pokémon if you’re hunting for shinies or stardust.
4. Launch and Monitor: Start the automated route. The tool will now create a self-sustaining loop: you gain XP and Stardust from catches, restock items from spins, and hatch eggs from the distance covered. This turns your device into an incredibly efficient farming machine.
Here are direct answers to the most common questions about how to catch Pokémon automatically.
Yes. Using any third-party software that alters or automates gameplay is explicitly against Niantic’s Terms of Service. This applies to software-based auto catchers and GPS modification tools. Hardware accessories like the Pokémon GO Plus+ are permitted because they use the official, intended game API.
There is always an inherent risk. No software-based tool can be considered 100% safe. You can significantly mitigate this risk by following the safety guidelines in this guide: obey cooldowns, simulate human-like movement, and moderate your usage. The risk is never zero, but it can be managed.
Niantic uses a tiered penalty system. A first offense typically results in a 7-day warning and a temporary “soft ban” (e.g., Pokémon always fleeing). Repeated violations can lead to a 30-day suspension and, in severe cases, permanent account termination.
Hardware devices are paired via Bluetooth through the game’s settings menu. Software apps are installed on your device (as detailed in our setup section), after which you configure settings like movement speed and which items to use. Once activated, the service runs in the background to perform actions for you.
Yes, but only when combined with an auto-walking or GPS movement feature. Egg hatching is based on distance traveled. If your tool simulates walking a route, it will automatically contribute to hatching your eggs.
The best Pokémon GO auto catcher in 2026 depends on what you value most. If account safety is your top priority, Pokémon GO Plus+ is still the best official choice. If you want a more hands-free experience, Go-tcha or Dual Catchmon may be more practical. If you are looking for a Pokémon GO auto catcher app, remember that software tools usually offer more features but also bring higher ban risks.
For players who want better farming efficiency, pairing a hardware auto catcher with a realistic walking route tool like Fonelora Location Changer can create a smoother setup. The safest strategy is not to automate everything aggressively, but to choose the right tool, move naturally, and avoid gameplay patterns that look impossible.
