Learn how to follow routes in Pokémon GO safely on iOS and Android. This guide explains how to auto-walk efficiently to hatch eggs faster while minimizing ban risk.
Are you tired of the slow grind of hatching eggs in Pokémon Go? Many dedicated players find their progress stalls because manual walking is so time-consuming. You might want to explore automated solutions, but the fear of account suspension makes the process feel incredibly risky. We understand that frustration. Searching for a safe tool often leads to confusing advice and a dead end.
This guide provides a clear, tested procedure for setting up automated routes safely. We will recommend specific, reliable tools we’ve tested and show you exactly how to configure them to mimic natural movement and avoid detection. Learning how to follow a route in Pokémon Go this way allows you to consistently gain distance for eggs and buddy candy without needing to physically travel for hours.
If Pokémon GO is not tracking your Route, it’s usually due to GPS accuracy issues, missing location permissions, or the route not being started correctly. Make sure your phone’s Location Services are set to “Always Allow”, enable Adventure Sync in the game settings, and start the route from its official starting point. Poor GPS signal, walking too fast, or temporary bugs from Niantic servers can also prevent progress from being recorded. Restarting the app or updating it to the latest version often fixes the issue.
Before you begin, it’s important to understand the two primary methods for following a route in Pokémon Go: using the official in-game Routes feature and employing third-party GPS simulation tools. Each approach has different benefits and drawbacks. Making an informed decision here is key to achieving your goals, whether you need an efficient Pokémon Go egg hatching route or want to explore new areas virtually.
To help you decide which approach fits your needs, consult the comparison table below. It confirms that for automation, GPS tools are the correct choice.
| Feature | In-Game Routes | GPS Simulation Tools |
| Automation | None (Manual Walking) | Full (Automated Movement) |
| Efficiency | Low | High |
| Account Safety | 100% Safe | Safe with Precautions |
| Physical Effort | High | None |
| Best For | Earning Zygarde Cells | Hatching Eggs, Earning Candy |
For iPhone users, setting up a custom route requires a dedicated desktop application that connects to your iPhone with a USB cable. This method does not require jailbreaking your device, keeping it secure. The main function is to create a controlled, simulated movement between two or more points on the map.
This is where Fonelora Location Changer fits naturally into the workflow. Instead of relying on unstable mobile GPS apps or risky jailbreak methods, FLC allows you to manage your iPhone or Android GPS location from a computer. For route-based Pokémon GO gameplay, it can help you select a starting point, create a walking path, adjust movement speed, and simulate more natural movement for egg hatching or buddy candy progress.
We recommend using Fonelora Location Changer for players who want a cleaner desktop-based setup. It offers practical route planning, location changing, and movement simulation without needing to modify the device system. The key is to use it carefully: keep the walking speed realistic, avoid sudden long-distance jumps, and always follow cooldown rules.
Your character inside Pokémon Go will now begin moving along the specified route on your iPhone, accumulating distance for your eggs and buddy.
Important: Fonelora Location Changer is a GPS simulation tool, not an official Pokémon GO feature. Use it responsibly, avoid unrealistic jumps, and prioritize account safety when planning any route.
Android users can set up a Pokémon Go auto walk route directly from their device using a mock location app from the Google Play Store. The process involves enabling a standard Android feature called Developer Options, which does not require rooting your phone or compromising its security.
For Android, you can use a mock location app from Google Play, or choose a desktop-based tool like Fonelora Location Changer if you want a more controlled setup from your computer. Free Android mock GPS apps may work for simple walking routes, but they can sometimes cause the “rubber-banding” effect where your location snaps back and forth. A desktop tool is often easier to manage if you want smoother route control across both iOS and Android.
Expert Tip: Preserve Your Session
Before starting a long route, close all other background apps on your phone. Some Android systems have aggressive memory management that can shut down the mock GPS app if it’s running in the background for a long time, which would halt your progress. Keeping other apps closed helps ensure your session runs without interruption.
Using GPS simulation tools always involves some risk, but you can minimize it significantly by making your simulated activity as human as possible. Niantic’s anti-cheat systems are designed to detect unnatural movement like instantaneous travel over long distances (“teleporting”) or perfectly constant speeds over long periods.
The most critical insight for safety is this: following a route is safest when the movement is smooth, gradual, and imperceptible. Simulating a realistic walking speed along a planned route is the best way to avoid triggering warnings.
The 5 Rules of Safe Route Simulation
Whether you use a mobile mock location app or a desktop option like Fonelora Location Changer, the same principle applies: the route should look like a real person walking, not a bot drawing perfect lines across the map.
Once you have mastered the technical setup with a reliable tool, the next step is strategic planning. An efficient route is one designed to meet a specific goal. Simply walking in a random direction is less effective than planning a route to maximize rewards for the time invested.
Most simulation tools will pause your movement. When you reconnect, your character in Pokémon Go should reappear at the last registered location. It is generally safe, but you may need to restart the route simulation in your tool.
On iPhones, since the tool runs on a computer, your phone is free to use. On Android, it’s possible, but as mentioned in our expert tip, heavy multitasking can cause the operating system to close the GPS app to save memory. For long sessions, it’s best to let it run without other intensive apps open.
We generally advise against free tools. Many are unreliable, filled with ads, or, in some cases, contain malware. More importantly, they often lack the sophisticated features like variable speed and smooth movement simulation that are critical for avoiding detection. Investing in a reputable, paid tool is an investment in your account’s safety.
A speed between 5 km/h and 10 km/h (about 3-6 mph) is both safe and effective for hatching eggs and earning buddy candy. This range closely mimics a natural walking or jogging pace and is unlikely to trigger anti-cheat systems.
Absolutely. A planned, automated route ensures you are constantly accumulating distance at an optimal speed without interruption. This is far more efficient and consistent than manual walking, which often involves stops, starts, and inconsistent speeds.
The frustration of slow egg hatching and the time required for manual walking doesn’t have to hold back your progress. By following the clear procedures in this guide, you can safely and effectively automate your movement, turning what was once a time-consuming chore into an efficient background activity. The key is to choose a reliable tool and prioritize safety by simulating realistic, human-like movement.
For iPhone users, or for Android players who want a more controlled desktop setup, Fonelora Location Changer offers a practical way to create routes, adjust movement speed, and manage GPS simulation from a computer without jailbreak or root. Combined with careful route planning and safe movement habits, it can make Pokémon GO route walking easier to manage.
You no longer have to worry about account suspension or the risk of downloading unsafe software. Take control of your gameplay and start hatching eggs more efficiently today.
