If you are wondering how to get a Sun Stone in Pokémon GO, you should know that the game relies primarily on spinning location markers. Because the item drops are based heavily on Random Number Generation (RNG), there is no single button to press to get one instantly. Instead, you have three official methods to acquire it:
Ultimately, acquiring this item requires consistent spinning and patience, as the drop system is entirely randomized.
Before you dedicate time to farming PokéStops, it helps to confirm who you actually want to use the stone on. In Pokémon GO, the Sun Stone is used to evolve a specific group of Grass, Fire, and Electric-type Pokémon.
Here is the complete checklist of Pokémon that require a Sun Stone to evolve:
If you are holding onto one of these Pokémon with high stats, you will need to start stockpiling spins to find the stone.
If you are frustrated because you have spun dozens of stops and still haven’t found a Sun Stone, the math validates your experience. The historical drop rate for any evolution item from a standard PokéStop spin is roughly 1%.
This means that for every 100 stops you spin, you might see just one evolution item. Furthermore, that 1% drop rate shares a loot pool with other evolution items like the Metal Coat, King’s Rock, Dragon Scale, and Up-Grade.
Many players rely on the 7-day spin streak to bypass this low rate, as completing a 7-day streak guarantees an evolution item drop. However, the streak reward still pulls from the same random pool. You might hit your 7-day streak and receive a King’s Rock instead of the Sun Stone you actually need. Because the system is purely RNG-based, the only true workaround is brute-forcing your spin volume by visiting best Pokémon GO locations with massive clusters of PokéStops.
Knowing that you need to spin hundreds of PokéStops to guarantee a Sun Stone is fine if you live in a dense city. But this game mechanic creates a massive disadvantage for geographically limited players.
Imagine a scenario where a player lives in a rural area or suburbs with only one or two PokéStops within walking distance. Standard guides advise these players to “just walk around the park more.” But if that park only has two stops, brute-forcing a 1% drop rate is physically impossible without spending hours waiting for the 5-minute spin cooldowns to refresh.
Manual grinding fails when you simply do not have the geographic infrastructure to support high spin volumes. For players locked out of dense PokéStop clusters, route simulation has emerged as a valid, practical alternative strategy to level the playing field and farm items efficiently.
If you are tired of manual grinding against a 1% drop rate or simply lack the nearby PokéStops to farm effectively, you can change location in Pokémon GO to simulate a walking route through high-density areas remotely.
Fonelora Location Changer is a desktop-tethered utility for supported iOS and Android devices that allows you to manage virtual movement safely. Unlike riskier modded apps that require you to install altered versions of the game directly on your phone, Fonelora works by altering the GPS coordinates at the device level while you play on the official app.
To farm Sun Stones, Fonelora’s Multi-Spot Mode allows you to create an auto-walking route through known PokéStop clusters—like major city parks—right from your computer. By using Game Mode and following the built-in Cooldown Timer, you can manage your account risk responsibly, simulating realistic walking speeds to spin stops as you “pass” them virtually. While no location changing method is 100% ban-free, using a tethered desktop approach with strict cooldown management is a much more safety-conscious method for gathering evolution items.
Realistic GPS movement simulation, flexible route control, easy no-modification setup, and support for gaming, social, privacy, and location-based testing in one platform.
Setting up a virtual farming route takes only a few minutes. Here is how you can use Fonelora Location Changer to walk between PokéStops automatically and hunt for that Sun Stone:
1. Connect your device: Open Fonelora Location Changer on your Windows or Mac computer, connect your supported iOS or Android device via USB or Wi-Fi, and select Game Mode. Be sure to follow the on-screen prompts to enable Developer Mode (for iOS) or USB Debugging (for Android) when connecting for the first time.
2. Check your Cooldown Timer: Before jumping to a new location, ensure you do not have an active cooldown. Fully close the Pokémon GO app on your phone and observe Pokémon GO cooldown rules before making initial long-distance jumps.
3. Map your route: Select Multi-Spot Mode from the upper right corner of the interface. Click along a high-density PokéStop area to create a continuous walking path.
4. Set a realistic speed: Adjust the movement speed slider to a normal walking or cycling pace to keep your movement looking natural.
5. Start farming: Click ‘Move’ to begin the simulation. Open Pokémon GO on your device and either manually spin the PokéStops as your avatar walks past them, or connect an auto-catcher device to do it for you.
Q1: What Pokémon evolve with a Sun Stone?
A Sun Stone is used to evolve Gloom (into Bellossom), Sunkern (into Sunflora), Cottonee (into Whimsicott), Petilil (into Lilligant), and Helioptile (into Heliolisk).
Q2: What is the drop rate of Sun Stones from Pokestops?
The drop rate for any evolution item, including the Sun Stone, is historically around 1% from standard PokéStop and Gym spins.
Q3: How can I get a Sun Stone fast in Pokémon GO?
Because drops are entirely RNG-based, the fastest way is to massively increase your spin volume by walking through dense clusters of PokéStops or using auto-walking route simulation if you cannot access dense areas physically.
While the 1% drop rate of Sun Stones is entirely out of your control, your daily spin volume is not. To get the evolution items you need for your Gloom or Helioptile, maximizing the number of PokéStops you hit is the only guaranteed strategy.
For players in busy cities, dedicating an afternoon to walking through a park filled with stops is often enough to trigger a drop. However, if you are a rural player or simply tired of manually grinding against bad RNG, you have other options. By using Fonelora Location Changer, you can set up a safe, auto-walking route on your desktop and farm PokéStop clusters efficiently without leaving home.
If geographic limitations are keeping you from evolving your favorite Pokémon, check your device compatibility and try setting up your first Multi-Spot route with Fonelora today.
More Related Articles
