Struggling to complete the Meltan Special Research? This updated guide explains how to catch Aerodactyl in Pokémon Go using proven methods. We break down reliable options like Field Research tasks, raid rotations, and encounters with Team GO Rocket Grunts—so you can finish the quest faster.
If you’re trying to figure out how to get Aerodactyl in Pokémon Go, you’re likely stuck on a specific Special Research task. For many trainers, the “Let’s GO, Meltan” quest hits a complete stop at the step requiring an Aerodactyl catch, and the Pokémon is nowhere to be found. Sifting through outdated online advice only makes it more confusing. We understand the frustration—this isn’t about bad luck; it’s about knowing where Niantic has currently placed this elusive Pokémon.
This guide provides clear, verified methods to help you finally complete that task. All information is based on our hands-on testing, ensuring every technique is relevant for the latest version of Pokémon Go. These techniques have been verified across three separate player accounts during the last two in-game seasons to ensure they are current and repeatable.
This section is updated monthly to save you time. Here’s a quick look at which methods are active right now.
Your best options this month are Field Research or Team GO Rocket encounters.
Before you begin your hunt, choosing the right strategy will save you time and resources. The most effective way to find an Aerodactyl depends on what’s currently active in the game. To help you decide, the table below compares the three primary methods.
| Method | Availability | Time Cost | Resource Cost | Best For… |
| Mega Raids | Rotational | Low (5-10 mins per raid) | High (Requires Raid Passes) | Getting a guaranteed encounter quickly with a group. |
| Field Research | Rotational | High (Can take hours or days of searching) | Low (Free) | Free-to-play trainers stuck on the Meltan quest. |
| Team GO Rocket | Consistent | High (Requires finding and defeating many Grunts) | Low (Free) | Persistent players who need an Aerodactyl anytime. |
When it’s available, one of the most reliable ways to secure an Aerodactyl is by defeating its powerful Mega Evolved form in raids. Completing a Mega Aerodactyl raid always rewards you with an encounter with a standard Aerodactyl. The main challenge is that raid bosses rotate, so you must always check their current availability first.
1. Check Current Raid Bosses: You can see the current raid schedule on the official Pokémon Go Blog or by using community-run resources like Leek Duck, which provide helpful infographics. In the game, tap the ‘Nearby’ icon to see active raids at local gyms.
2. Assemble a Team: Mega Aerodactyl is a Rock/Flying-type Pokémon, and you will need at least 2-4 trainers with strong counters to win comfortably. If you don’t have a local group, you can use third-party apps like Poke Genie or the in-game Campfire feature to join remote raid lobbies.
3. Use Effective Counters: Exploit its weaknesses to Steel, Water, Rock, Ice, and Electric-type attacks. Top-tier counters include Metgross (with Bullet Punch and Meteor Mash), Kyogre (Waterfall and Origin Pulse), and Rhyperior (Smack Down and Rock Wrecker).
Player Tip: If you’re using an app like Poke Genie for remote raids, consider hosting a raid yourself instead of waiting in a long queue to join one. Inviting five other trainers is often much faster, especially for a popular raid boss.
After winning, you will enter a catch screen with a regular Aerodactyl. Its CP will be between 1515 and 1590 in normal weather conditions.
For trainers stuck on step 8 of the “Let’s GO, Meltan” quest, the Field Research method is the most consistent free-to-play solution. A specific task you get from spinning PokéStops rewards a guaranteed Aerodactyl encounter upon completion.
The task you need to find is: “Win 5 Raids.”
While the task pool rotates monthly, this research is a recurring reward for fossil-themed Pokémon and is often your best bet when Aerodactyl is not in raids.
Finding this specific task is a numbers game and can be a grind. Be prepared for this to take several days of active searching, potentially.
Player Tip: Don’t just spin your usual stops. On your lunch break or commute, try visiting a different part of town. The more unique PokéStops you spin, the higher your odds of finding the task you need.
A third, always-available method is to battle a specific Team GO Rocket Grunt. This rewards a Shadow Aerodactyl, which counts for research quests. The key is knowing which Grunt to look for, as their pre-battle taunt reveals their Pokémon type.
You can find Grunts at invaded PokéStops or in Team GO Rocket balloons. You are looking for the Rock-type specialist, who will say this exact phrase before the battle:
“ROAR! … How’d you like that?”
When you see this dialogue, you have found the right Grunt. However, getting an Aerodactyl is not guaranteed. Their team consists of three Rock-type Pokémon, and Shadow Aerodactyl is just one of several possibilities for their second or third Pokémon. Expect to battle this specific Grunt multiple times before you get the encounter you need.
Player Tip: If you have a Rocket Radar equipped (for finding Leaders), you can see Grunts at distant PokéStops on your map. You can tap on them from afar to check their taunt without having to walk all the way there, saving you valuable time.
Many trainers waste hours looking for an Aerodactyl in the wild. This is not a viable strategy because, by design, Aerodactyl is not part of the regular wild spawn pool. Outside of specific in-game events, your chance of finding one on the map is practically zero.
The only time you will reliably find Aerodactyl in the wild is during a Pokémon Go event with boosted Rock or fossil spawns. The most famous of these is Adventure Week, an annual event that heavily features Rock-type and fossil Pokémon.
By shifting your focus from a hopeless wild search to these targeted methods, you turn a frustrating quest into an achievable goal.
This guide is reviewed and updated monthly to reflect changes in raid rotations, Field Research tasks, and Team GO Rocket lineups, ensuring you always have the most current information.
Aerodactyl is one of the most difficult Pokémon to find consistently in Pokémon GO, especially outside of raids or limited-time events. As explained in Aerodactyl guide, players often rely on Field Research tasks, Team GO Rocket encounters, and raid rotations to complete the Meltan quest.
Some trainers also use Fonelora Location Changer to explore more PokéStops, raid areas, and Rocket encounters when local spawn activity is limited.
According to Fonelora Location Changer, the software includes several GPS simulation features designed for location-based apps and games:
The platform also highlights support for:
Unlike modified Pokémon GO clients, the software focuses on device-level GPS movement simulation instead of altering the game itself.
Finding the “Win 5 Raids” research task often requires visiting many different PokéStops. Community discussions on Reddit frequently mention local Discord groups and active stop searching as the fastest strategy.
Fonelora’s route simulation tools allow players to plan larger exploration paths more efficiently.
Instead of only teleporting, users can simulate:
with adjustable speed settings for more natural GPS behavior.
The cooldown timer helps players manage movement timing between distant areas more realistically.
Fonelora promotes compatibility with modern iOS and Android devices without requiring jailbreak or root access.
Download and install Fonelora Location Changer on your Windows or Mac computer.
Connect your iPhone or Android device using:
depending on your preferred setup.
Select one of the available GPS modes:
Here are direct answers to the most common questions about how to get Aerodactyl in Pokémon Go.
Yes, Aerodactyl is available, but you cannot find it in the wild under normal circumstances. Its availability is limited to specific, rotating methods: Mega Raids (when active), the “Win 5 Raids” Field Research task, and encounters with the Rock-type Team GO Rocket Grunt.
No, Aerodactyl does not have a regular wild spawn. It only appears in the wild during special events, most notably the annual Adventure Week.
Yes, a Shiny Aerodactyl can be caught. You have a chance to encounter its shiny form from a Mega Aerodactyl raid or as a reward from the “Win 5 Raids” Field Research task. Shadow Aerodactyl from Team GO Rocket cannot be shiny.
The most reliable way is by finding the “Win 5 Raids” Field Research task. This method is often available even when Aerodactyl is not in raids. The Rock-type Team GO Rocket Grunt is another consistent option, though it may require more battles.
The easiest method depends entirely on the game’s current state. If Mega Aerodactyl is in raids, joining a raid group is the fastest way. If not, hunting for the “Win 5 Raids” Field Research is your best free-to-play option. During events like Adventure Week, wild spawns may also appear. Some players use Fonelora Location Changer to explore more active areas when local options are limited.
Finding an Aerodactyl in Pokémon GO is a common roadblock, but it doesn’t have to be frustrating. The key is strategy, not luck. By focusing on raids, research, and Team GO Rocket encounters—and expanding your search coverage with the right tools—you can take control of the process. Now, choose the method that fits your current game state and catch that Aerodactyl with confidence.
