Fix Error 12 and avoid soft bans in Pokémon GO with our expert teleportation solutions. Learn how to manage cooldowns, spoof safely, and troubleshoot issues on both iOS 18 and Android to keep your gameplay smooth and secure.
You spot the coordinates for a regional exclusive you have been hunting for months. You jump to the location, the Pokémon appears, you throw a Golden Razz Berry, and… it flees instantly. You try to spin a PokéStop, but it spins indefinitely, offering no items.
This is the nightmare of every location-based gamer. Whether you are facing a soft ban where every catch fails, or the technical frustration of Pokemon go teleport not working due to “Error 12,” the result is a locked game when you need it most.
Take the case of Chris, a dedicated player who recently tried to catch a regional Pokémon in Tokyo from his home in Los Angeles. He assumed his device was broken when everything fled. In reality, his software was fine; his timing was flawed. This guide provides a tested Pokemon go teleport fix that solves connection errors and keeps your account safe.
If you have ever asked, “Why is my Pokémon Go soft ban teleport fix not working?”, the answer usually lies in the game’s server-side logic, not your phone’s hardware. Most teleport problems occur because players interact with the game too soon after moving locations.
The game calculates the time required to travel between two points physically. If you cross that distance instantly and interact immediately, the server flags the action as physically impossible. This results in a “Soft Ban”—a temporary block where Pokémon flee, and stops don’t drop items.
Many guides fail to explain this distinction. You can teleport 10,000 miles away and still be safe, provided you do not trigger the cooldown.
Actions that TRIGGER a Cooldown (Wait time required):
Actions that DO NOT Trigger Cooldown (Safe to do anytime):
You can “”Shiny Check”” freely. Teleport to a coordinate, tap the Pokémon, and if it isn’t shiny, run away. You have not triggered a cooldown and can immediately teleport to the next coordinate.
To apply a Pokemon go teleport fix, strictly adhere to these wait times based on distance traveled:
Expert Insight: The “2-hour rule” is the absolute maximum. Even if you jump 10,000 km, the server resets your location log after two hours of inactivity. If you are wondering how long to wait after teleporting, the safest answer for any international or cross-country jump is always 120 minutes.
When troubleshooting why Pokémon Go failed to detect location teleport, the tool you use is often the culprit. There are two primary categories of location changers.
This method involves connecting your phone to a computer (PC/Mac). The software on the computer overrides the GPS data sent to your phone. This is currently the safest method for iOS 17 and iOS 18 users.
Mobile-only apps (APKs/IPAs) are convenient but risky or difficult to set up.
To perform a Pokémon Go spoof teleport fix that avoids “Failed to Detect Location,” you must follow a specific sequence. We will separate this by operating system, as iOS and Android require different handling.
Modern iOS versions have high security. You cannot simply “trust” the computer; you must enable Developer Mode.
2. Launch Desktop Software: Open your chosen tool (e.g., iAnyGo, MockGo) on your computer.
3. Connect Device: Plug your iPhone into the computer via USB.
4. Enable Developer Mode (Crucial Step):
The software will likely prompt you to do this, but if not: Go to Settings > Privacy & Security.
Scroll to the bottom and tap Developer Mode.
Toggle it ON.
5. Select Coordinates: In the desktop software, enter your destination (e.g., Pier 39, San Francisco).
6. Execute Teleport: Click “Move.”
7. Launch Game: Open Pokémon GO. You should be in the new location.
The trick on Android is handling the “Mock Location” setting correctly.
Step 1. Enable Developer Options:
Step2. Configure Mock Locations:
The Nuance:
If you are using a desktop tool, it may install a helper app on your phone (often named “GPS Assistant” or similar). You must select this helper app here.
If you are using a distinct mobile spoofer, select that app.
Step 3. Connect & Teleport:
Step 4. Preventing Rubber-Banding:
Android phones aggressively try to find your real GPS signal. If your avatar snaps back to your real house:
If you see the red banner “Failed to detect location (12),” your game knows you are simulating GPS.
This happens when your phone oscillates between your fake location and your real location.
If the map on your desktop software loads but your phone doesn’t move:
Sometimes the spoofing “stalls.”
Understanding the severity of your issue is vital. Many users panic when they encounter Pokemon GO spoofing errors, fearing they have lost their account permanently. It is helpful to distinguish between a soft ban and a shadow ban, as the solutions are completely different.
A Soft Ban is a “speeding ticket.” It happens when you move too fast. It resolves itself automatically once the cooldown timer (max 2 hours) expires. Symptoms include Pokémon fleeing immediately and PokéStops yielding no items. You do not need to reinstall the game; just wait.
A Shadow Ban is more severe and is usually caused by using modified mobile apps (like a hacked version of Pokémon GO). In this state, you can still play, but you will not see any rare Pokémon on the map for approximately 7 days. This is a formal warning from Niantic.
If you stick to the Pokemon GO soft ban fix (waiting) and use the recommended desktop tools (which do not modify the game code), you generally avoid the shadow bans.
When Pokémon GO teleporting stops working, the problem is often caused by outdated spoofing methods or unstable GPS override tools. Many players experience issues such as Error 12, rubber-banding, failed teleports, or sudden GPS resets after game updates.
To improve spoofing stability on modern iOS and Android devices, many players now prefer desktop-based GPS spoofing tools instead of modified game apps.
One reliable option is Fonelora Location Changer, a desktop location changer designed for both iPhone and Android devices without requiring jailbreak or root access.
Unlike modified Pokémon GO clients that may trigger account warnings, desktop tethered tools work by overriding the device GPS location directly, which is generally considered a safer approach for long-term gameplay.
Here are some features that make Fonelora useful for Pokémon GO teleport fixes:
For players dealing with the “Failed to Detect Location (12)” error, updated desktop-based tools are often more reliable than older mobile spoofing apps.
Download and install Fonelora Location Changer Official Website on your Windows PC or Mac.
Launch the program after installation.
Use a USB cable to connect your iPhone or Android phone to the computer.
For iPhone users:
Modern iOS spoofing methods often rely on Developer Mode for stable GPS overriding.
For Android users:
Inside the Fonelora map interface:
Your device GPS location will instantly change.
Popular Pokémon GO farming areas often include locations such as Tokyo, Zaragoza, and New York due to dense PokéStop clusters and raid activity.
Q1. Why is teleport not working in Pokémon GO?
Teleportation usually fails due to either a soft ban (interacting too quickly after moving) or Error 12, where the game detects mock location settings. Ensure your desktop tool is updated to support the latest iOS/Android patch.
Q2. How do I fix Pokémon GO soft ban after teleport?
The only reliable Pokemon GO soft ban fix is time. You must wait for the cooldown period to end. Spinning stops 40 times is an old myth and no longer works.
Q3. Can I teleport without triggering a cooldown?
Yes. You can teleport anywhere in the world as long as you do not catch, spin, battle, or drop a berry. You can “shiny check” indefinitely without waiting.
Q4. Which tools are best for iOS 18?
For iOS 17 and 18, desktop-tethered tools like iAnyGo, AnyTo, or MockGo are currently the most stable options because they utilize Developer Mode to override GPS without hacking the game app itself.
Q5. What causes Error 12 in Pokémon GO?
Error 12 is a “Failed to Detect Location” warning. On Android, it means your Mock Location settings are visible to the game. On iOS, it usually means Developer Mode is disabled or the location spoofer has lost connection to the device.
Q6. Can teleporting get your account banned?
Excessive teleporting that ignores cooldowns triggers soft bans. However, using modified game clients (downloaded from 3rd party stores) is the primary cause of permanent bans. Using standard desktop GPS override tools is generally safer for your account health.
Resolving a Pokémon Go teleport fix issue doesn’t have to be a gamble. Whether you are stuck behind a soft ban or staring at Error 12, the solution is to use a trusted desktop tool (like iAnyGo, MockGo, or Fonelora Location Changer) and respect the cooldown timer. By properly configuring Developer Mode on iOS or Mock Locations on Android, you can eliminate the frustration of fleeing Pokémon.
Do not let technical glitches ruin your hunt for rare regionals. Regain control of your game today by applying these steps. If you are ready to explore the world, secure your setup now and catch them all safely.
