Want to solve iTunes error 3014? Read this article carefully to know the best ways to fix iTunes error 3014.
There is no doubt that iOS devices are top-notch and the most durable among all mobile devices. However, while using iTunes, the Apple-developed tool, to manage data on iOS device or update iOS, problems like iTunes error 3014 never give people a break. iTunes error 3014 mainly occurs when users try to update or restore their devices and it is frustrating while updating your device software, especially when you are keenly waiting for a new update.
If you are stuck in iTunes error 3014, don’t worry, here in this post, we will show you why iTunes error 3014 occurs and how to fix it. Keep reading and get more.
iTunes error 3014 is actually a very common error that can appear at any time. There are many reasons behind that leads to iTunes error 3014. Some reasons are given below.
· Virus or harmful program.
· Apple iTunes software files get corrupted in Windows registry.
· iTunes is not successfully installed on your computer.
· Some other app of the firewall is interfering with iTunes services.
There are five fixes in total. In order to fix iTunes error 3014 more quickly, please try them one by one.
Tip 1. Check Your Host File:
Checking the host file is one of the best ways to fix iTunes error 3014 on your Mac computer. In order to perform this, you have to update your iTunes software to the latest version. Once this process successfully completed, you can check your host files with the following steps.
Step 1Open Finder and click on Terminal to open it.
Step 2On Terminal, type sudo nano/private/etc/hosts and hit “Enter” button.
Step 3Enter computer password and press “Enter” again.
Step 4After this step, you will see hosts file on the terminal window. Navigate to entries in front of gs.apple.com and add # symbol in front of the entry.
Step 5Save the file by pressing Control + X and hit on “Enter” button. Restart your computer to apply changes.
Tip 2. Update Your Computer OS Software:
Outdated computer software is also the reason behind iTunes error 3014. You can update your computer to the latest version in order to get new features, performance improvement, and minor bug fixes. There may be some system software that is not able to communicate with Apple server while updating or restoring the iOS devices.
To update Mac OS, you should open App Store on your Mac computer and then click Updates from the toolbar. If there is an available update, click Update and you can install the new OS on your system.
To update Windows, you should go to Control Panel > System and Security > Windows Update. Wait until the system completely checks any available software update. If there are any available updates, click on important updates and check the boxes for any updates you want to install, click Install Updates.
Tip 3. Check Computer Time & Date
Under some circumstances, wrong date & time on the computer may cause a problem in communicating with Apple’s servers. It would be easy and simple to practice setting the correct time, date, and time zone correctly.
Tip 4. Close the Firewall
If you are using anti-virus or other third-party software, you can turn off the firewall which blocks the communication with Apple’s servers.
To close the firewall, you should go to Control Panel > System and Security > Windows Firewall. Click Turn Windows Firewall on or off from the left side menu options.
Tip 5. Update iTunes
Apple launches iTunes update to fix bugs. Do always open and access iTunes to check if there are any updates.
To update iTunes on Mac: Launch iTunes on Mac. At the top of iTunes’s menu bar screen, click iTunes > Check for Updates. If there are available updates, follow the prompts, you can have the latest iTunes.
To update iTunes on PC: Launch iTunes on Windows PC. From the iTunes’ menu bar, click Help > Check for Updates. You can then install the latest iTunes by following the prompts.
Don’t Miss: How to Fix iPhone iPad Could Not Be Restored >
iTunes error 3014 can be fixed with above five methods. However, solving problems like iTunes error 3014 is indeed complicated and time-consuming. Moreover, iTunes itself has many functional limitations. For instance, iTunes can’t backup all data on your iOS devices, data in iTunes backup are not viewable.
For all mentioned above, you will need an iTunes alternative to help you manage iPhone data. Here we recommend you try AnyTrans for iOS.
Developed by iMobie team, AnyTrans for iOS represents the revolutionary progress in iOS data management. It is trusted by thousands of users to backup iOS data and restore iOS devices because AnyTrans for iOS:
Besides, AnyTrans for iOS is developed by an Apple certificated developer and now it is also Norton and McAfee secured. While using it, accidents like information leakage or data loss would never occur.
If you need to create a backup of your iPhone or transfer data from computer to iPhone, why not get AnyTrans for iOS now and start the 7-day free trial?
That’s all for how to fix iTunes error 3014. Are those tips helpful? Do leave comments below so that others may benefit. By the way, as you can see, AnyTrans for iOS is indeed an excellent iTunes alternative to help you backup iPhone data and restore iPhone from previous backups. Give it a try!
Users Served
