Have you forgotten your OPPO phone password? Unlocking your device is important to regain access to valuable data. This guide explores the top OPPO password unlock tools to help you unlock your phone without a password. Read and learn more here!
Free download DroidKit to unlock the OPPO screen without hassle. No matter if you forgot the pin, pattern, or face recognition, DroidKit can help you regain access to your phone with a few clicks.
Forgot your OPPO phone password and locked out of your device? Whether you forgot your PIN, pattern, fingerprint lock, or screen password, there are several OPPO unlock tools that can help you regain access. Some tools are beginner-friendly and work in just a few clicks, while others are designed for advanced users and repair technicians.
In this guide, we compare the best OPPO unlock tools for PC, including official recovery methods, free solutions, flashing tools, and professional Android unlock software. You’ll learn:
Different OPPO devices and lock situations require different solutions. This quick comparison helps you choose the right OPPO unlock tool faster.
| Your Situation | Recommended Solution |
| Forgot PIN, pattern, or password | DroidKit |
| Need beginner-friendly unlock tool | DroidKit |
| Want official Google method | Find My Device |
| Phone stuck on bootloop or software issues | MSM Download Tool |
| Advanced user with USB debugging enabled | ADB |
| Need completely free method | Factory Reset |
| Want fastest PC unlock solution | DroidKit |
| Don’t mind erasing all data | Factory Reset |
| Need system-level flashing solution | MSM Download Tool |
| Tool | Difficulty | PC Required | Data Loss | Best For |
| DroidKit | Easy | Yes | Usually Yes | Beginners |
| Find My Device | Easy | No | Yes | Official remote reset |
| Factory Reset | Medium | No | Yes | Basic unlocking |
| MSM Download Tool | Advanced | Yes | Yes | Repair technicians |
| ADB | Advanced | Yes | Depends | Developers & advanced users |
If you want the easiest and safest way to unlock an OPPO phone without technical knowledge, DroidKit is one of the best options available.
Unlike complicated flashing tools or command-line methods, DroidKit provides a simple step-by-step unlocking process that works for most users.
It supports multiple lock types, including:
The tool supports over 20,000 Android devices, including many OPPO models.
Step 1. Download DroidKit on your computer and install it, then connect your OPPO phone using a USB cable.
Step 2. Open DroidKit and select the “Screen Unlocker” option from the main screen.
Select Screen Unlocker Mode
Step 3. Wait while DroidKit sets up a configuration file tailored to your OPPO phone.
Preparing Configuration File for OPPO
Step 4. Select “Wipe Cache Partition” in Recovery Mode and confirm the action.
Wipe Data in Recovery Mode
Step 5. DroidKit will complete the unlock process, and your OPPO phone will restart without a password.
Unlock OPPO Screen Successfully
If you prefer official or completely free solutions, the following methods can help unlock your OPPO phone. However, most official methods erase all device data.
Google Find My Device allows users to remotely erase and unlock Android devices linked to a Google account.
This is one of the easiest official methods if your OPPO phone still has internet access enabled.
Step 1. Open Google Find My Device on another device or computer.
Step 2. Sign in using the Google account linked to the locked OPPO phone.
Step 3. Select your OPPO device from the device list.
Step 4. Click Factory Reset Device.
Step 5. Confirm the reset process.
After the reset finishes, the screen lock will be removed.
Factory reset is one of the most common free methods for unlocking an OPPO phone.
This method works directly through Recovery Mode and does not require additional software.
Step 1. Power off the device completely.
Step 2. Press and hold the Power + Volume Down buttons simultaneously.
Step 3. Enter Recovery Mode.
Step 4. Select Wipe Data / Factory Reset.
Once completed, your OPPO phone will restart without the old screen lock.
After resetting your device, OPPO phones may still require the previously synced Google account because of FRP (Factory Reset Protection).
This is a built-in Android security feature designed to prevent unauthorized access after a reset.
The following methods are designed for advanced users, developers, or repair technicians. They are more powerful but also more complicated and risky for beginners.
As one of the OPPO password unlock tools, MSM Download Tool offers a practical way to update firmware and unlock screen locks. It is mainly developed for OPPO phones. Users who need to repair software issues or return their OPPO phone to factory settings may find it extremely helpful. The simple user interface makes the procedure easier for novice and seasoned users.
Key Features:
Cons:
For using MSM Download Tool. Follow the steps below:
Step 1. Download the flash tool and flash files to your computer. Extract them using WinRar.
Step 2. Copy the files from the “flash-tool” folder and paste them into the “flash-file” folder.
Step 3. Run “MSMDownloadTool.exe” as administrator and enter your username and password (after purchasing the premium version).
Enter Username And Password
Step 4. When the tool opens, click “Start All” to begin the process. It will load the firmware files.
Step 5. Connect your OPPO phone to the computer via USB and press the “Volume Down + Power” buttons to enter recovery mode.
Step 6. Once the connection has been made, the device manager should display “Qualcomm HS-USB QDLoader 9008.”
Check Device Manager
Step 7. It will begin flashing the ROM and new firmware to unlock your OPPO phone.
The command-line program ADB (Android Debug Bridge) can give users substantial control over Android devices. With precise instructions, users may install/uninstall apps, remove screen locks, and fix their devices. Developers and tech-savvy individuals often use ADB to perform various tasks on Android devices, including unlocking them when other methods fail.
Key Features:
Cons:
To use this tool, check out the steps below:
Step 1. Install ADB on your PC and open a Powershell window by pressing Shift + Right Click. Connect your OPPO phone via USB.
Open Powershell Window
Step 2. Check if ADB works by typing “adb devices” in the command window.
Step 3. Hold Power, Home, and Volume Up/Down to enter ClockworkMod recovery.
Step 4. To remove the screen lock, use the “adb shell rm /data/system/gesture” command.
Remove Screen Lock on OPPO
For most beginners, DroidKit is one of the easiest OPPO unlock tools because it provides guided steps and supports many Android devices.
In most cases, unlocking an OPPO phone will erase device data for security reasons. Some official recovery methods may preserve data depending on the device status.
Yes. Factory Reset and Google Find My Device are free official methods. However, they usually erase all device data.
This usually happens because of FRP (Factory Reset Protection). After reset, the phone may require the previously synced Google account.
For beginner users, DroidKit is one of the most user-friendly OPPO unlock tools for PC. Advanced users may prefer MSM Download Tool or ADB.
This post examined the top 5 OPPO unlock tools—DroidKit, OPPO Password Unlock, Android Device Manager, MSM Download Tool, and ADB—for unlocking OPPO screen locks without a password. DroidKit is a fantastic option for users seeking a hassle-free solution because of its user-friendly interface and speedy unlocking process. Android users can unlock Android from a PC with no privacy worries via this reliable tool. Free download DroidKit, try it now!
