Joy Taylor
Joy Taylor | Last Updated: May. 28, 2026
Trying to track down the “Alloy Pokémon” can feel like searching for a needle in a haystack—if that needle was a massive, skyscraper-shaped Dragon-type. Whether you’re like Emma, a Raid Hunter looking to bolster your competitive lineup, or a Pokédex Collector trying to fill that frustrating shadow, getting Duraludon requires timing and strategy.
Here is everything you need to know about how to get Duraludon in Pokémon GO.
How to Get Duraludon Pokemon Go
Where to Find Duraludon in Pokémon GO
Unlike Pidgeys or Rattatas, Duraludon isn’t a Pokémon you’ll typically find just by taking a casual stroll through the park. In the current 2026 meta, Duraludon is primarily tied to special events and Raid rotations.
1. Pokémon GO Raids
The most reliable way to catch Duraludon is through Pokémon GO raids. As a Dragon/Steel type, it often appears as a 3-star or even a Mega Raid boss during themed events (like “Dragon Weeks” or “Steel Type Showcases”).
imobie tips
Keep an eye on your “Nearby” raid tracker. If you see a metallic, tower-like silhouette on top of a Gym, grab your Raid Pass
2. Event Pokémon Spawns
Niantic frequently features Duraludon during limited-time events. During these windows, you might find them:
  • In the wild (with increased spawn rates).
  • As rewards for Field Research tasks (e.g., “Win 3 Raids” or “Catch 10 Dragon-types”).
  • Hatching from 10km Eggs during specific seasonal rotations
3. Special Research & Seasonal Rotations
Occasionally, Duraludon is offered as an encounter in Seasonal Special Research. Because Pokémon GO spawn rotations change every few months, a Pokémon that is rare today might be everywhere tomorrow.
How to Catch Duraludon: Raid Strategies
If you find a Duraludon raid, you need to be prepared. Since it is a Steel/Dragon type, its weaknesses are different from your standard dragons.
Weakness Best Counters
Fighting Lucario, Conkeldurr, Machamp
Ground Groudon, Garchomp, Excadrill
Avoid using: Grass, Poison, or Flying-type moves, as Duraludon resists these heavily. Stick to heavy hitters like Counter/Aura Sphere Lucario to end the raid quickly.
Using Fonelora Location Changer for More Flexible Pokémon GO Exploration
For players who frequently miss out on raid rotations or region-specific spawns in Pokémon GO, Fonelora Location Changer provides a more flexible way to manage device GPS positioning across supported iOS and Android devices. It is a PC-based location management tool that does not require jailbreak or root access, making it accessible for most users who want more control over how location-based apps behave.
Unlike basic mock location apps that often fail against modern game detection systems, Fonelora works at the system level through a computer connection, allowing users to simulate movement or teleport between locations in a more stable environment. This makes it particularly useful for checking raid availability in other cities, participating in time-limited events, or simply understanding how different regions appear inside Pokémon GO.
Step 1. Install Fonelora Location Changer on your Windows PC or Mac.
Step 2. Connect your smartphone to the computer using a USB cable and tap “Trust This Computer” if prompted.
Connect Your Device
Connect Your Device
Step 3. Launch the software and choose a mode such as Teleport Mode or Joystick Mode.
Step 4. Search for the desired location where raids or events are active.
Step 5. Click “Move” to apply the new location on your device.
Change Your GPS Location
Once completed, your device’s location will be updated across supported apps, allowing you to explore different in-game regions more flexibly during Pokémon GO events.
Can Duraludon spawn in the wild?
Rarely. While it can appear in the wild, it is considered an “Ultra Rare” spawn outside of specific events. Your best bet remains Raids and Eggs.
Is Shiny Duraludon available?
As of current updates, Shiny Duraludon has been released during major global events (like GO Fest or Safari Zones). Look for a distinct chrome/silver body with different colored accents!
Can you trade Duraludon in Pokémon GO?
Yes! If you have a friend with an extra Duraludon, you can trade for it. Since it isn’t a Mythical Pokémon, it only costs the standard amount of Stardust (though a “Special Trade” is required if you haven’t caught one before).
What type is Duraludon?
Duraludon is a dual Steel and Dragon-type Pokémon. This is a fantastic defensive typing, as it neutralizes the typical Dragon-type weakness to Fairy and Ice moves.
Tips for the Dedicated Hunter
If you’re struggling to keep up with limited-time events, staying organized and proactive is key.
  • Join Local Groups: Use Discord or Campfire to find active raid communities and coordinate with other trainers in your area.
  • Check Event Calendars: Duraludon frequently appears during special events such as Lunar New Year or “Ultra Unlock” rotations, so planning ahead is essential.
  • Update Your App: Make sure your device (iOS 15–18 or Android 11–14) is running the latest version of Pokémon GO to access current raid bosses and event spawns.
For trainers who want additional flexibility in how they access different in-game regions, some also use tools like Fonelora Location Changer. It allows users to manage and adjust their device’s GPS location on iOS and Android via a PC connection, helping simulate different locations in a controlled way. After installing the software, connecting the device, selecting a target area, and clicking “Move,” players can explore how raids and spawns appear in different regions more easily while staying updated on global events.
Related Articles
How to Fake Location on Life360 Without Alerts (2026 Guide)
BlueStacks Pokemon GO Review: Setup Guide and Safe Alternatives
How to Hide IP Address: Privacy & Security Guaranteed (2026)
Can You Fake Your Location on Find My?
