Quick Answer: Necrozma will officially return to Pokémon GO raids in July 2026 during the highly anticipated “Road of Legends” and “GO Fest Global” events.
If you missed out on gathering enough energy during previous events, here are the exact dates you need to know:
Because these raid hours are based on “local time,” the availability of these legendary forms rolls across the globe time zone by time zone. This means players who understand how global schedules work can potentially participate in multiple raid hours before the event officially starts in their own city.
Navigating global Pokémon GO events can be tricky because Niantic schedules specific raid hours based on your device’s local time. Here is the exact breakdown of the 2026 schedule:
| Necrozma Form | Event Date | Raid Hour (Local Time) | Associated Fusion Energy |
| Dawn Wings Necrozma | Tuesday, July 7, 2026 | 6:00 PM – 7:00 PM | Lunar Fusion Energy |
| Dusk Mane Necrozma | Wednesday, July 8, 2026 | 6:00 PM – 7:00 PM | Solar Fusion Energy |
When an event is set for “6:00 PM to 7:00 PM local time,” it doesn’t happen for everyone at once. Raid hotspots like Tokyo or Sydney will experience their 6:00 PM raid hours long before players in London or New York wake up. For players looking to plan ahead, finding the best places to spoof Pokémon GO globally is often a priority.
For a standard player, this simply means waiting for 6:00 PM to arrive in their city. But for trainers looking to max out their legendary Pokémon, time zone math becomes the key to farming massive amounts of Fusion Energy. Catching multiple timezone raid hours allows you to raid continuously, but it introduces a whole new set of geographic limitations.
Fusing a standard Necrozma with Lunala or Solgaleo requires an enormous amount of Lunar or Solar Fusion Energy—typically 1,000 energy per fusion. If you rely strictly on walking around your local neighborhood, gathering enough energy in a single one-hour window is incredibly difficult.
Here is why relying on local play often falls short:
Because of these limitations, serious players often look for ways to virtually cross time zones to participate in major global hotspots like Tokyo or New York. However, doing so requires specific strategies to overcome the game’s geographical restrictions.
Before you consider using a location tool to access international Necrozma raids, you must understand the strict mechanics governing location changes in Pokémon GO. Instantly jumping long distances triggers account safety mechanisms.
When you interact with the game (such as catching a Pokémon or spinning a PokéStop) in one location, you trigger a “cooldown timer.” If you instantly teleport to another country and try to catch a raid boss before that timer expires, you will face a “soft ban.” During a soft ban, Pokémon will immediately flee, and PokéStops will not yield items. Learning the Pokémon GO cooldown rules is mandatory if you want to farm energy globally.
It is critical to note that no location-changing method is 100% ban-free. Results always vary based on third-party app rules, your device OS, and platform risk controls. Unstable or outdated fake GPS apps frequently fail to manage these cooldowns and are easily detected, leading to the dreaded “Error 12” (Failed to detect location) or flagged accounts.
If you want to raid globally without paying for expensive remote passes, you need a workflow that explicitly helps you manage cooldown periods and simulates natural movement, rather than just jumping recklessly around the map.
If your local area lacks active raiders and you want to avoid the high cost of Remote Raid Passes, using a guided desktop tool to manage your virtual location is a practical alternative. This is where a dedicated Pokémon GO location changer like Fonelora Location Changer comes in.
Realistic GPS movement simulation, flexible route control, easy no-modification setup, and support for gaming, social, privacy, and location-based testing in one platform.
Fonelora Location Changer is a desktop-based software that allows users to change the GPS location on supported iOS and Android devices. Unlike risky, unrestricted mobile apps that often lead to Error 12, Fonelora uses a controlled desktop connection to help you virtually travel to global raid hotspots like Tokyo, London, or New York.
Why it helps with LBS games:
Fonelora features a specialized Game Mode designed specifically for location-based game workflows. More importantly, it includes a built-in Cooldown Timer that calculates exactly how long you need to wait after moving long distances. This feature helps you respect the game’s cooldown rules before you attempt to spin a gym or join a Necrozma raid, significantly helping you manage account risks while farming Fusion Energy globally.
Farming enough Solar and Lunar Fusion Energy requires a strategic, cooldown-aware workflow. Here is how you can use Fonelora Location Changer to safely access global raid hours across multiple time zones under supported conditions:
By following this guided workflow, you can successfully gather enough energy for both Dawn Wings and Dusk Mane fusions without being restricted to a single local hour. If you want a more controlled way to manage international raids, you can change location in Pokémon GO using Fonelora Location Changer to start planning your GO Fest routes today.
The 2026 return of Necrozma is an unmissable event for Pokémon GO players. Mark your calendars for July 7 (Dawn Wings) and July 8 (Dusk Mane) from 6:00 PM to 7:00 PM local time. Because acquiring enough Solar and Lunar Fusion Energy requires multiple high-tier raids, strategic planning is essential—especially if your local raid community is quiet.
If you find yourself bottlenecked by a lack of local players or the strict daily limits and high costs of Remote Raid Passes, a guided virtual location workflow can bridge the gap. By using Fonelora Location Changer on a supported iOS or Android device, you can virtually access major global raid hotspots. Features like the Cooldown Timer and Game Mode give you the controlled environment you need to farm Fusion Energy across time zones.
Remember, no location changer is entirely free from account risks. Always play responsibly, verify app rules, and let your cooldown timers reach zero before jumping into the next big raid.
More Related Articles
