Joy Taylor
Joy Taylor | Last Updated: Jul. 8, 2026
Quick Answer: If you are searching for “Zamazenta Crowned Sword,” you have actually mixed up the two Galar legendaries! In Pokémon GO, Zacian is the Crowned Sword Pokémon (Fairy/Steel-type), while Zamazenta is the Crowned Shield Pokémon (Fighting/Steel-type).
This naming mix-up is incredibly common in the community. To transform either of these Pokémon from their standard Hero of Many Battles form into their powerful Crowned forms, you need to collect specific Crowned Energy.
Whether you are trying to upgrade your Zacian or Zamazenta, exploring Pokémon GO guides will walk you through the raid mechanics, the best counters to defeat them, and how players in areas with limited local raids can access global raid events to farm the required energy safely.
How to Get Crowned Energy & Best Raid Counters
To perform the form change for Zacian or Zamazenta, you need a substantial amount of Crowned Energy. The primary way to obtain this energy is by defeating them in active Crowned form raids during special events.
Because they have different typings in their Crowned forms, you need entirely different teams to counter them effectively. Here is a quick breakdown of their weaknesses and the best counters to use in raids:
Feature Zacian (Crowned Sword) Zamazenta (Crowned Shield)
Typing Fairy / Steel Fighting / Steel
Weaknesses Ground, Fire Fighting, Ground, Fire
Top Counters Primal Groudon, Mega Charizard Y, Reshiram Terrakion, Mega Blaziken, Primal Groudon, Reshiram
Required Energy Crowned Sword Energy Crowned Shield Energy
Farming enough energy requires completing multiple raids. For players with highly active local communities, chaining together three to five local raids during an event is standard. However, as we will see, this requirement creates a massive roadblock for many players.
The Catch: Why Local Raids Aren’t Always Enough
Farming enough Crowned Energy requires successfully beating multiple Zacian or Zamazenta raids. Unfortunately, this highlights a major pain point in Pokémon GO: rural players, or those without an active local player base, often struggle to find enough populated raids to clear these difficult tier-5 and Mega-level bosses.
Even if a Crowned raid spawns nearby, defeating it solo is mathematically impossible for most players. Furthermore, these legendary raids are usually tied to strict, time-limited global events. If you live in an area with few gyms, poor weather, or timezone mismatches, you may end the event without enough energy to form-change your legendary.
This geographical restriction forces many players to look for alternative ways to join active global raid hotspots, where lobbies fill up instantly.
Understanding Cooldowns Before Joining Global Raids
Before looking into tools that help you access global raids, it is crucial to understand Pokémon GO’s movement rules. Niantic uses strict cooldown mechanics to monitor long-distance travel. If you jump from a local gym in your hometown to a raid in Tokyo, you cannot interact with the game immediately without triggering penalties like Error 12 or a soft ban.
Use this checklist to understand Pokémon GO cooldown rules before attempting to join global raids:
  • Understand the Cooldown Chart: The maximum cooldown time is generally 2 hours for a jump over 1,500 kilometers. You must wait this out before spinning a PokéStop, catching a wild Pokémon, or throwing a Premier Ball at a raid boss.
  • Raid Interactions Count: While you can sometimes enter a lobby, dropping a Raid Pass or trying to catch the defeated Zacian/Zamazenta will trigger a soft ban if your cooldown has not reset. The boss will simply flee.
  • Manage Account Risk: No virtual location tool provides 100% immunity to bans or Error 12. Safe raid farming requires strict adherence to cooldown timers.
  • Use the Right Tools: If you plan to teleport, you need a workflow that helps you manage these timers rather than guessing when it is safe to play.
Farming Global Raids with Fonelora Location Changer
For rural players who cannot find local raid lobbies, finding a practical way to access global hotspots like New York, Tokyo, or Zaragoza is the only way to farm enough Crowned Energy. This is where Fonelora Location Changer becomes a highly relevant tool to securely change location in Pokémon GO.
Realistic GPS movement simulation, flexible route control, easy no-modification setup, and support for gaming, social, privacy, and location-based testing in one platform.
Fonelora Location Changer is a guided desktop application that helps you change the GPS location of supported iOS and Android devices. Instead of relying on unstable fake GPS apps or risky on-device spoofers that easily trigger Error 12, Fonelora handles movement through a stable desktop connection.
More importantly for Pokémon GO players, its dedicated Game Mode features a built-in Cooldown Timer. This timer calculates the exact wait time required after you teleport, helping you manage movement rules carefully. By using Fonelora under supported conditions, you can teleport to an active global raid, wait for the cooldown to expire, and join full lobbies to farm energy without leaving your home.
Step-by-Step: Teleporting to Active Raids Safely
Farming Crowned Energy via global raids requires patience and a structured workflow. Here is how to use Fonelora Location Changer to join raids responsibly:
Connect Your Device: Launch Fonelora Location Changer on your computer and connect your supported iOS or Android device via USB or Wi-Fi.
Connect Your Device
Connect Your Device
Select Game Mode: Choose the LBS Game Mode from the menu, which applies game-oriented setups designed for titles like Pokémon GO.
Use Teleport Mode: Enter the coordinates of a known active raid hotspot (such as Zaragoza, Spain) and click to move your virtual location.
Select Teleport Mode
Observe the Cooldown Timer (Mandatory): Fonelora’s interface will display a required cooldown time. You must wait for this timer to reach zero before you interact with the gym, drop a raid pass, or attempt to catch the boss.
Complete the Raid: Once the cooldown is clear, open the game, join the packed lobby, defeat the Crowned boss, and collect your Crowned Energy.
By strictly following this workflow and respecting the timer, you can accumulate the energy needed to transform your Zacian or Zamazenta.
  • Why are players confused by Crowned Sword and Crowned Shield?
  • Many players search for “Zamazenta Crowned Sword,” but this is a mix-up. Zacian is the Crowned Sword Pokémon, and Zamazenta is the Crowned Shield Pokémon. They require different types of Crowned Energy to transform.
  • How do I get Crowned Shield Energy to transform Zamazenta?
  • You must defeat Zamazenta in its Crowned Shield form during special raid events. Completing the raid rewards you with the specific energy needed for the form change.
  • Is Crowned Zamazenta better than Crowned Zacian for PvP?
  • Both are incredibly powerful in the Master League, but they serve different roles. Zacian (Sword) dominates with its Fairy typing, while Zamazenta (Shield) is an excellent Fighting/Steel physical wall. The “better” choice depends on your team composition.
  • What are the best counters and weaknesses for Crowned Zamazenta?
  • As a Fighting/Steel-type, Crowned Zamazenta is weak to Fighting, Ground, and Fire attacks. Top counters include Primal Groudon, Reshiram, and Terrakion.
  • Can I catch Crowned Zamazenta in the wild?
  • No. Crowned forms are strictly raid-exclusive. You catch them in their standard form post-raid, or you use energy you farmed from the raids to transform a Zamazenta you already own.
  • How can I find global Zamazenta raids if none are local?
  • You can coordinate with remote raid discords to use Remote Raid Passes, or use a tool like Fonelora Location Changer on supported devices to teleport to highly populated geographical hotspots.
  • How does the cooldown timer work when teleporting to Pokémon GO raids?
  • If you use a location changer to jump a long distance, you trigger a cooldown period (up to 2 hours). You cannot spin stops or catch the raid boss until this timer expires, otherwise the boss will flee and you may face a soft ban.
Final Thoughts: Unleash Your Crowned Legendaries
Clearing up the “Zamazenta Crowned Sword” mix-up is just the first step. Unlocking the true potential of Zacian and Zamazenta requires farming a massive amount of Crowned Energy from high-tier raids.
For players without an active local community, acquiring this energy can feel impossible. While remote passes are an option, they are expensive and strictly limited. Teleporting to global raid hotspots is a highly effective alternative, but it demands strict adherence to the game’s cooldown rules to protect your account.
If you are tired of missing out on special raid events, Fonelora Location Changer provides a practical, cooldown-aware workflow. By utilizing its Game Mode and built-in Cooldown Timer, you can safely navigate to active global lobbies under supported conditions. Before jumping in, be sure to check your specific iOS or Android device compatibility on the official page, or try the free version to ensure the setup works smoothly for your system. Download a Pokémon GO location changer to start farming the Crowned Energy your legendaries deserve.
More Related Articles
fonelora img
  • Bluetooth Hardware Simulation for Safer GPS Spoofing
  • Realistic Movement & Route Simulation
  • No Root or Jailbreak Required
  • All-in-One Solution for Games, Social Apps & Privacy
Change GPS Location Easily
Free Download Free Download
