Activation Lock is Apple’s anti-theft feature that ties an iPhone to an Apple ID. Even after a factory reset, the device cannot be set up or used without the original Apple ID and password, helping prevent unauthorized access or theft.
Quick Answer: Activation Lock is an Apple anti-theft system that links an iPhone to an Apple ID and is part of iPhone unlock Activation Lock protection. It blocks setup, erase, or use without the correct login.
If you see “iPhone Locked to Owner,” the lock is still active, even after reset. Many users search iPhone locked to owner how to unlock, but without the original Apple ID, the device cannot be activated.
Activation Lock is different from Bypass SIM lock iPhone, which only affects carrier restrictions.
There is no valid Activation Lock bypass code.
The best way to handle Activation Lock is to avoid buying a locked phone in the first place. Whether you are buying on Facebook Marketplace, Craigslist, or from a friend, always verify the device status before handing over your money.
Here is your essential pre-purchase checklist:
Getting scammed is unfortunately common in the second-hand market. If you already paid for the device, took it home, and discovered the Activation Lock screen, you are in a difficult spot. Your recovery options shrink rapidly depending on your relationship with the seller.
Here is a realistic breakdown of your options:
| Option | Best For | Requirement | Reality Check |
| 1. Contact the Seller | Honest mistakes | The seller must answer your messages and remove the device via iCloud.com. | This is the only official, free, and permanent way to remove the lock. |
| 2. Contact Apple Support | Legitimate resale | You must have the original proof of purchase from the first buyer. | Apple is incredibly strict. They will not accept an eBay receipt. |
| 3. Third-Party Bypass Tools | Ghosted buyers | A supported older iPhone model and specific iOS version. | This is a last resort. Tools like the FRPFILE iCloud bypass tool and others have strict hardware limits and disable cellular data. |
If the seller ghosts you and you do not have the original store receipt, your official avenues are entirely exhausted. At that point, you must decide whether to recycle the phone or explore limited software workarounds.
A common myth among used iPhone buyers is that Apple Support will gladly unlock the device if you can prove you paid for it. Unfortunately, this is not true.
Apple has an incredibly strict verification policy to prevent thieves from laundering stolen phones. They explicitly reject second-hand receipts. Showing an eBay invoice, a PayPal transaction record, a Facebook Marketplace chat log, or a handwritten bill of sale will not work.
To remove Activation Lock, Apple requires the original proof of purchase. This means the store receipt from the very first person who bought the phone brand-new from Apple or an authorized carrier. The receipt must clearly show the device’s IMEI or serial number. While this policy effectively protects legitimate owners, it leaves honest second-hand buyers stuck with a locked phone if they were scammed by a reseller.
If the seller disappeared and Apple rejected your request, you might be searching for software bypass tools. Before you proceed, it is critical to understand that there is no “magic tool” that effortlessly unlocks any iPhone, and many online claims give false hope.
Here are the strict realities and limitations you must accept before trying a tool-assisted bypass:
If you are completely stuck—the seller ghosted you, Apple rejected your second-hand receipt, and you are okay with the device becoming Wi-Fi only—AnyUnlock offers a guided desktop workflow as a last resort.
AnyUnlock provides a structured toolkit to help users attempt an Activation Lock bypass on lawfully owned or authorized devices. Because it relies on specific iOS vulnerabilities, you must check your device model and iOS version compatibility first.
What if you get locked out of your iPhone? Or what if you forgot your Apple ID and its password? No worries, AnyUnlock unlocks any iOS lock for you with 1 click. No technology required. Only 3 steps.
Here is how the guided desktop workflow works:
1. Verify your device: Ensure you have a supported older iPhone model and compatible iOS version.
2. Open the AnyUnlock toolkit: Launch the software on your Windows or Mac computer and select the “Bypass iCloud Activation Lock” module.
3. Connect the iPhone: Plug your locked device into the computer via a USB cable.
4. Follow the on-screen jailbreak guidance: AnyUnlock will safely guide you through the necessary jailbreak process required for the bypass.
5. Bypass the lock: Follow the final prompts to bypass the Activation Lock screen.
Once completed, you can set up the iPhone and regain basic Wi-Fi access, allowing you to salvage a phone that would otherwise be a permanent paperweight.
Can I use cellular data after an Activation Lock bypass?
No. Bypassing Activation Lock using third-party software usually disables cellular capabilities. You will not be able to make traditional phone calls or use mobile data, turning the iPhone into a Wi-Fi-only device.
How do I avoid buying a stolen iPhone?
Always meet in a public place with Wi-Fi, run the device’s IMEI through an online checker (see our iUnlocker review) to ensure it isn’t blacklisted, and most importantly, walk through the setup screen before paying. If it asks for an Apple ID, do not buy it.
Can I remove activation lock without the previous owner?
Officially, no. Apple requires the original proof of purchase to remove it without the owner. Unofficially, you can use desktop tools like AnyUnlock for supported older models, but you must accept the functional limitations like losing cellular access.
Is bypassing the activation lock permanent?
No. Software bypasses are tethered to the current iOS installation. If you perform a factory reset, erase all content and settings, or update the iOS, the Activation Lock will reappear.
Will a factory reset remove the Activation Lock?
No. Activation Lock survives factory resets and system restores. Because the lock is tied to Apple’s remote servers, erasing the local data on the phone does not remove the security restriction.
Some users also look for an Activation Lock bypass code, but no such code exists, as Activation Lock is server-based and cannot be bypassed locally.
Quickly and easily unlock your iPhone/iPad/iPod touch from various locks such as screen lock, MDM lock, iCloud activation lock, Apple ID, iTunes backup password, and more.
Related Articles:
* Broque Ramdisk Pro Latest Version Free Download
* 007 Ramdisk Tool Review
* IMEI Unlock Software Review
