Catching a new Pokémon is genuinely thrilling. Looking at your Pokédex and not knowing the full evolution tree, however, can cause immediate frustration. I remember staring at my screen years ago, clutching my phone, completely paralyzed by the choice between the Gardevoir and Gallade evolutions. I had just caught a perfect-stat male Ralts during a rainy commute, and I almost completely wasted it because I did not fully understand the game’s hidden mechanics.
That same kind of uncertainty often happens with other evolution lines too, whether you are researching Ralts or comparing guides like Pokémon Piplup evolution to plan your next upgrade. Since that day, I have extensively tested these evolution systems across countless devices—from older Android 6 phones to the latest iOS 18 hardware—verifying exactly how candy requirements, gender conditions, and evolution items dictate your gameplay. Hardware never changes the server-side mechanics, but game knowledge absolutely changes your success rate.
If you are experiencing deep confusion over your evolution options or struggling with difficulty finding Ralts in the wild to optimize your resources, this strategy guide offers a battle-tested solution. We will explain exactly what Ralts evolves into in Pokémon Go. By following these specific steps, you will master the evolution mechanics, ensuring you never waste hard-earned candies or rare items on the wrong decision.
Table of ContentsHide
To successfully evolve your Pokémon, you must strictly follow the sequential resource requirements programmed into the game. The progression from the base stage to the final forms demands a precise amount of evolution candy.
Here is a critical expert insight: In Pokémon Go, Ralts evolves into Kirlia with 25 candy and then into Gardevoir with 100 candy. However, Kirlia can also evolve into Gallade if it is male and the player uses a Sinnoh Stone. Because Gallade requires both gender conditions and a specific item, strategic players plan their evolutions carefully to avoid wasting resources.
Before you press any buttons, follow this exact step-by-step method to navigate the evolution stages effectively:
Step 1. Secure the Base Pokémon: Catch or hatch a Ralts to add it to your storage screen.
Step 2. Appraise Your Pokémon (The IV Check): This is the most crucial step for any strategic player. Do not blindly spend 125 rare candies on a 0-star Pokémon. Tap the menu on your Ralts and select “Appraise” to check its Individual Values (IVs). You want to invest your resources into a 3-star or 4-star Pokémon for maximum battle efficiency.
Step 3. First Stage Evolution: Accumulate 25 candies to evolve your chosen Ralts into Kirlia.
Step 4. Inspect the Gender: Tap on your Kirlia to open its profile screen. Look directly next to its name for the gender symbol. A male Kirlia displays a ♂ symbol, and a female Kirlia displays a ♀ symbol.
Step 5. The Gardevoir Route: To obtain Gardevoir, spend 100 candies on any Kirlia (male or female) by tapping the primary pink Evolve button.
Step 6. The Gallade Route: To obtain Gallade, ensure the Kirlia is male, spend 100 candies, and apply a Sinnoh Stone using the secondary Evolve option.
⚠️ WARNING: DO NOT MISCLICK YOUR MALE KIRLIA!
If you have an excellent male Kirlia and you specifically want a Gallade, pay close attention to your screen. The primary pink Evolve button will turn your male Kirlia into Gardevoir. To get Gallade, you MUST tap the secondary Evolve option that displays the Sinnoh Stone icon next to it. Accidentally tapping the top button is a massive trap that ruins perfect male candidates. Female Kirlias will only ever display the top button.
Using this structured solution ensures you meet all game requirements without error, protecting your high-stat catches from accidental misclicks.
Once you secure the necessary resources, you face a critical choice regarding your final evolution. Choosing the correct final stage requires strategic analysis rather than casually evolving random catches. Evaluating both options against specific performance criteria ensures you build a highly effective battle roster tailored to your exact gameplay goals.
Gardevoir retains the highly coveted Psychic and Fairy-type combination. This unique typing makes it an absolute monster for Player versus Environment (PvE) content. When equipped with moves like Charm and Dazzling Gleam, Gardevoir excels at shredding Fighting-type Team GO Rocket grunts and melting Dragon-type raid bosses. It’s serious damage output secures an incredibly consistent raid-clearing time.
Conversely, Gallade is a Psychic and Fighting-type Pokémon. It generally outputs less raw damage in high-tier raids compared to Gardevoir. Instead of being a generalized attacker, Gallade serves as an excellent specialized tool for trainers needing Fighting-type coverage against Normal, Rock, and Steel types in specific gym-clearing scenarios.
For Player versus Player (PvP) battles, the two Pokémon serve vastly different roles. Gallade is a highly sought-after tool for farming GBL (GO Battle League). It demands higher technical skill to operate effectively, but its diverse move pool—specifically the fast energy generation paired with Close Combat and Leaf Blade spam—makes it an incredible specialist for experienced trainers competing in the Ultra League. For Ultra League Gallade, you actually want an IV spread with low Attack and high Defense and HP to maximize its bulk.
Gardevoir offers a much more straightforward, heavy-hitting approach. In formats like the Master League Premier, a high-IV Gardevoir relies on sheer fast-attack pressure, using Charm to aggressively chunk down opponents’ health bars before they can even fire off a charge move.
Strategic players should reserve their strongest male Kirlias for Gallade to secure their PvP roster, and evolve their best female Kirlias into Gardevoir for raiding.
| Feature | Gardevoir | Gallade |
| Typing | Psychic / Fairy | Psychic / Fighting |
| Candy Cost | 100 Candies (from Kirlia) | 100 Candies (from Kirlia) |
| Item Required | None | Sinnoh Stone |
| Gender Required | Any (Male or Female) | Male Only |
| Best Use Case | Melting Dragon-type Raid Bosses | Farming GBL in Ultra League |
Accumulating the 125 total candies required for your final evolution is a constant obstacle. A limited supply of candy significantly slows down your progress. You can apply several targeted techniques to accelerate your collection rate and secure your final evolutions much faster. By mathematically optimizing your catches, you can drastically reduce your farming time.
Implementing these exact strategies will help you secure enough resources for your evolutions:
Timing your evolution process during specific community events is a highly efficient optimization tool. Do not rely entirely on standard, everyday gameplay to farm resources. Niantic frequently hosts recurring annual events where Psychic and Fairy types spawn heavily.
Mark your calendar for the annual Psychic Spectacular event, the Valentine’s Day event, and the December Community Day recap events. During these specific windows, Ralts’ spawn rates are dramatically boosted. Playing heavily during these named events directly solves the frustration of resource scarcity, moving your roster progression forward at lightning speed. Furthermore, evolving your Kirlia during Community Day recap events often rewards your Gardevoir or Gallade with the exclusive, powerful Community Day charge move, Synchronoise.
Finding enough Ralts candy can be slow if your local area has limited Psychic or Fairy-type spawns. While a location tool cannot change Ralts evolution requirements, increase shiny odds, or guarantee rare spawns, it can help players explore more active Pokémon GO areas when they need better access to PokéStops, events, or spawn-dense locations.
If you also need GPS-level location control for Pokémon GO, Fonelora Location Changer can be a practical companion tool. It lets you change GPS location on iPhone or Android from a Windows PC or Mac, without jailbreak or root, and supports joystick movement and route simulation for location-based gameplay.
Use it carefully. Avoid unrealistic long-distance jumps, follow cooldown rules, and keep your movement natural. Fonelora can support location-based farming, but your Ralts evolution still depends on the same in-game requirements: 25 candies for Kirlia, 100 candies for the final evolution, and a male Kirlia plus Sinnoh Stone for Gallade.
Executing the Gallade transformation requires a precise understanding of two strict variables: gender mechanics and evolution items. A massive point of friction for trainers is discovering that their Kirlia completely lacks the option to become Gallade. This occurs strictly because the Gallade evolution is entirely gender-locked within the game code. Female Kirlias are hard-coded to only evolve into Gardevoir. To trigger the Fighting-type transformation, your Kirlia must explicitly display the male gender symbol (♂) next to its health bar.
In addition to the male gender requirement, you must possess a Sinnoh Stone. This evolution item is a tremendous bottleneck for many players, and we need to be completely realistic about the acquisition mechanics here. The drop rates for Sinnoh Stones are heavily dependent on RNG (Random Number Generation), and the odds can be absolutely abysmal. You cannot simply walk to a PokéStop and buy one.
To reliably secure a Sinnoh Stone, you must grind through specific activities, knowing that it might take several days or even weeks of bad luck before one finally drops:
Using a combination of daily NPC battles and consistent GBL farming ensures you eventually overcome the RNG bottleneck and successfully evolve your team.
Mastering the Ralts evolution line instantly removes the confusion between Gardevoir and Gallade. By checking your Pokémon’s IVs, confirming Kirlia’s gender, saving enough candies, and understanding the Sinnoh Stone requirement, you can avoid wasting rare resources on the wrong evolution.
For most players, the safest strategy is simple: evolve strong female Kirlia into Gardevoir for reliable Fairy-type raid damage, and reserve strong male Kirlia for Gallade when you have a Sinnoh Stone and a clear PvP or collection goal. During Psychic Spectacular, Valentine’s Day, or Community Day recap events, focus on farming Ralts candy, catching high-IV candidates, and evolving at the right time for exclusive moves like Synchronoise.
If your local area makes Ralts farming difficult, Fonelora Location Changer can be a practical companion for location-based Pokémon GO activity. It allows you to change GPS location on iPhone or Android from a Windows PC or Mac, without jailbreak or root, and supports joystick movement and route simulation for exploring more active areas.
Use the evolution rules in this guide to make the right Gardevoir or Gallade decision, and use Fonelora Location Changer only when your goal is GPS-level location control for Pokémon GO farming. Always avoid unrealistic movement, respect cooldown rules, and keep your gameplay behavior as natural as possible.
Hot Topics
