HushSMS APK: Why It No Longer Works for FRP Bypass & Safe Alternatives (2026)
Searching for a safe HushSMS APK download? Learn why it fails on modern Android & discover the working alternative for FRP bypass in 2026.
Author Avatar Roger Smith Last Updated: Feb. 26, 2026
Searching for a HushSMS APK download often leads to unreliable sources, outdated guides, and conflicting instructions. Many users encountering a Samsung FRP lock turn to HushSMS hoping it can provide a quick solution. However, it is important to understand that HushSMS is a legacy tool with very limited compatibility, and it is no longer effective on current Android devices.
In this guide, we’ll explain what HushSMS was originally designed for, why it fails on Android 10 and newer, and what actually works today if your Samsung phone is FRP locked.
Quick Answer: Does HushSMS Still Work in 2026?
No. HushSMS does not work on modern Android devices.
  • It only supported a limited range of Samsung phones running Android 6–9
  • All SMS-based FRP bypass loopholes were permanently patched starting from Android 10
  • Downloading HushSMS APK files today carries high malware and data-theft risks
For Android 10–14 devices, SMS-based FRP bypass methods are no longer possible.
What Was HushSMS Originally Designed For?
HushSMS was developed for a specific range of older Samsung devices, primarily running Android 6 (Marshmallow) to Android 9 (Pie). It was not a universal bypass tool, but rather a method of exploiting how certain Android versions processed special SMS types.
Instead of bypassing security encryption directly, HushSMS operated by sending a special class of SMS messages from a secondary phone to the locked device. These included:
  • Class 0 (Flash) SMS: Triggered an on-screen pop-up with a link, often used to open a browser or the YouTube app.
  • WAP Push SL Messages: Directed the device to a specific URL, creating a pathway to system settings.
  • MMS Notifications: Exploited the handling of multimedia message requests to gain limited access.
  • Dialer Triggers: In rare cases, forced the dialer application to open.
Through these methods, users could temporarily access system functions and manually remove the Google account associated with the FRP lock.
Why HushSMS Fails on Android 10, 11, 12 and Newer
HushSMS does not work on any modern Android version (10, 11, 12, 13, or 14) or Samsung One UI (4, 5, 6). This is not a temporary issue—it is the result of deliberate security patches introduced by Google and Samsung years ago.
The loopholes that once allowed HushSMS to trigger browser or settings access via WAP Push SL or Class 0 SMS messages no longer exist. On Android 10+, these requests are ignored entirely at the lock screen level. If you encounter a guide or video claiming otherwise, it is either outdated or intentionally misleading. Attempting to use HushSMS on a modern phone will not unlock your device and will only waste time.
Android Version One UI Version HushSMS Support Status Reason for Failure
Android 6–9 Samsung Experience Partial (specific patch levels only) Security loopholes existed
Android 10 One UI 2/3 Not Working Google patched the WAP Push exploit
Android 11 One UI 3 Not Working Security policies further hardened
Android 12 One UI 4 Not Working Core SMS handling functions removed
Android 13–14 One UI 5/6 Not Working Secure-by-default system architecture
The Security Risk of Downloading HushSMS APK in 2026
Since the original developer (ub0r, distributed via XDA forums) no longer maintains HushSMS, the only downloads available are hosted on third-party APK mirror sites. This presents significant risks:
  • Malware & Spyware: Many files are modified to include hidden tracking tools or trojans.
  • Adware Injection: The app may run intrusive ads instead of performing its intended function.
  • Data Theft: Malicious builds can silently extract passwords, contacts, or financial information.
In other words, the bigger risk today is not that HushSMS won’t work—it’s that installing it could compromise your data on both the locked phone and the secondary phone used to send the messages.
⚠️ Warning: Installing apps from “unknown sources” bypasses Google Play Protect, leaving your device fully exposed.
How to Verify the APK (Legacy Devices Only)
If you are working with a very old device (Android 6–9) and insist on testing HushSMS, the only responsible way to proceed is to verify the APK integrity before installation.
  • Original App Name: de.ub0r.android.hushsms_26.apk
  • Original MD5 Checksum Hash: 53b79313a44b8b3b895a0242a5c51722
Quick Steps to Check the MD5 Hash on Android
  1. Download the APK file but do not install it yet.
  2. Install a hash checking tool from Google Play (e.g., Hash Droid, Checksum Tool).
  3. Open the tool and select the APK from your Downloads folder.
  4. Generate the MD5 hash for the file.
  5. Compare it with the original value: 53b79313a44b8b3b895a0242a5c51722.
  6. Match: File is likely original.
  7. Mismatch: File is modified and unsafe. Delete immediately.
HushSMS Not Working? Safe Alternatives for Modern Samsung Devices
Since HushSMS no longer works on modern Android versions, PC-based solutions are required for modern Samsung phones.
One widely used option is DroidKit, a professional Android system toolkit designed for:
  • Samsung FRP bypass (Android 10–14)
  • System repair and recovery
  • Screen lock removal on supported models
DroidKit does not rely on exploits or SMS loopholes. It uses official Android communication protocols and device-specific configurations, which is why it continues to work on modern systems.
HushSMS vs. DroidKit: A Modern Comparison
Feature HushSMS DroidKit
Method Sends a special SMS to an old phone Connects via PC to the phone in Download or Recovery Mode
Android Support Android 6-9 only Wide range, including Android 10-15
How it Works Exploits outdated SMS loopholes Uses official Android protocols and device-specific configurations
Requirements A second phone with SIM Windows PC or Mac, USB cable, and the locked phone
Reliability Very low on modern devices High, if device is supported
Safety High risk from unofficial APKs Verified and secure from official source
DroidKit offers a professional, safe, and highly reliable alternative to outdated HushSMS methods. By using official protocols and clear, step-by-step instructions, it ensures that your Samsung device can bypass FRP locks or repair software issues without exposing your personal data to malware.
How to Use DroidKit for FRP Bypass
Step 1: Prepare Your Device and PC
  • Ensure your Samsung phone is charged to at least 50%.
  • Download and install DroidKit on your Windows PC or Mac from the official website.
  • Use a quality USB cable to connect your FRP-locked Samsung device to your computer.
Step 2: Launch DroidKit and Select FRP Bypass
  • Open DroidKit and select the FRP Bypass module from the main dashboard.
  • Click Start to begin the process.
Launch the FRP Operation
Step 3: Follow On-Screen Instructions
  • DroidKit will detect your device and provide step-by-step instructions to put it into Download Mode or the appropriate bypass mode.
  • Carefully follow each step on both your PC and phone.
Go to Factory Mode
Go to Factory Mode
Step 4: Grant Necessary Permissions
  • When prompted on your phone, enable USB debugging and authorize the connection by selecting Always allow from this computer and tapping Allow.
  • DroidKit will then automatically configure the device for FRP removal.
Step 5: Complete the Bypass
  • The tool will perform the bypass procedure. Your device may restart several times.
  • Once completed, your Samsung phone will boot without the Google FRP lock, ready for a new account setup.
Attempting to use outdated apps like HushSMS on modern devices is ineffective and risky. Security architectures in today’s phones have evolved, and downloading unofficial APKs exposes your device to malware and data theft.
Instead, focus on modern, official tools like DroidKit, which are designed for contemporary Android versions and provide safe, step-by-step guidance. By using DroidKit, you can confidently bypass FRP on your Android device or repair software issues without compromising your personal data. With the correct approach, you can resolve your device problems efficiently and securely.
Frequently Asked Questions About HushSMS & Modern FRP Solutions
1. Does HushSMS still work on modern devices?
HushSMS only functions on very old Samsung phones running Android 6-9 that have never received firmware updates. For virtually all users with FRP-locked devices today, it is completely ineffective.
2. I tried #0# and nothing happened. What should I do?
This indicates that your device firmware has patched the legacy test mode access. Advanced bypass methods may be required, such as PC tools utilizing “Test Point” or “EDL Mode,” which can involve opening the device. At this stage, consulting a professional repair service is often the safest and fastest solution.
3. Is DroidKit safe to use?
When downloaded from the official website, DroidKit is considered secure by the Android repair community. The main risk is user error, as the tool performs system-level operations.
DroidKit – Unlock Android Screen in 1 click
  • Can unlock multiple screen locks like digital password, PIN, pattern, Touch/Face ID, etc.
  • Only need to click buttons. No root requirement. As simple as possible.
  • Compatible with almost all Android brands such as Huawei, Samsung, Sony, etc.
for all windows & 100% safe
for all mac & 100% safe
