3 Ways to Fix Samsung Tablet that Won’t Turn on or Charge
Tablet computers operating on Android are very popular and practical for private and professional purposes, and for the most part they work perfectly. However, if your Samsung Galaxy Tab won’t turn on or charge for whatever reason, read this article to get some smart tips for resolving this technical issue.
Author Avatar Roger Smith Last Updated: Sep. 12, 2025
Samsung is one of the leading manufacturers of mobile devices, with its smartphones and tablets widely used across the globe. The quality of the hardware is complemented by the fact that Samsung works closely with Google to make its devices compatible with the Android operating system. Because of this, any bugs or malfunctions are relatively rare, at least with high-end tablets.
Still, a Samsung tablet could refuse to turn on from time to time, preventing the owner from completing important tasks. Knowing a few potential fixes can save your day if this happens. With the methods described here, you should be able to fix your Samsung tablet on many occasions, saving you from having to take the device to be professionally serviced and wasting precious time and money.
Why is My Samsung Tablet not Charging or Turning on?
If you notice that your Samsung tablet is not charging or you can’t turn it on at all, you need to first diagnose the source of the problem. Depending on whether you are facing a hardware issue or just a software bug, you can determine your next actions.
If the device isn’t mechanically damaged and its battery is operational, the issue has likely originated with a system error that caused the tablet to freeze. Software problems, in general, can be fixed even without professional assistance, while a hardware failure might require you to change certain parts.
Start with making sure whether a faulty charger or battery might be causing the issue by plugging in the device and waiting for a while.
How to Fix my Tablet if it Won’t Turn on?
If your Samsung Tab won’t turn on even after you connect it to a charger and leave it plugged in for 20-30 minutes, you might have to use one of the following methods to try and resuscitate your device:
Restart the Device with Buttons
In normal circumstances, you need to hold down the Power button for only a few seconds to turn on the device. If this is not working, try holding the same button for much longer, up to 2 minutes to see whether the screen unfreezes. This could be effective if the contacts on the device have weakened or the tablet has been stuck on a black screen but needs some time to reset.
Restarting the tablet with the Power button is the simplest recovery method and you always should try it first before resorting to more invasive repair techniques.
Hard Reset
Rebooting the tablet with a hard reset is another possibility that could turn out to be successful. This method can also be executed very easily whenever a Samsung tablet freezes, but with the caveat that any applications or documents that were present on the device will be lost. Here is how you can reset a device that has been turned off and won’t come online again:
Step 1 – Simultaneously press and hold the Power and Volume up buttons on your tablet for about 15-20 seconds until the Recovery mode is activated
Step 2 – Use both volume buttons to navigate up and down through the menu and find the Wipe data/factory reset option
Step 3 – Tap on the Power button to select this option and then confirm your decision to factory reset your Samsung tablet
Revive a Dead Device with a System Repair Tool
In some cases, a third-party tool can solve the issue with a Samsung tablet that won’t turn off. Some data recovery apps such as DroidKit can fix a phone or tablet that won’t turn on due to system problems. So you can successfully bypass the frozen screen and revive a seemingly dysfunctional device within minutes. Because it can perform a number of essential tasks, from unlocking a device without a password to repairing system issues.
Besides, it is compatible with most Samsung and other Android-based tablets, it represents a smart alternative to a hard reset that could protect your data.
To repair your tablet with DroidKit, install this app to your computer, connect the tablet with USB, and choose Fix System Issues tab from the main menu. The interface of this app is very simple and logical, so just follow the instructions on the screen and you will soon regain control over your Samsung device. The procedure doesn’t require the tablet to be rooted, all of your data will still be on it once the black screen issue is successfully resolved.
What if Samsung Tablet Won’t Turn Off?
While the problem with Samsung Tab won’t turn on is more common, some users also experience a bug that prevents the tablet from shutting off. This can be very annoying and will certainly drain the battery very quickly, so learning an easy fix is highly recommended. The best approach to repair a Samsung tablet that won’t turn off is to reboot it from recovery mode, in a similar way to the method for turning on the device described in an earlier section. However, you should be aware that resetting the device in this manner will result in data loss and you will have to reinstall all applications.
Samsung tablets can refuse to turn on for several reasons, including an empty battery, minor hardware damage, or various software issues. The recovery methods described in this article can be effective in some cases, especially when the problem is caused by a simple software glitch. They are worth trying on your own before you come to the final conclusion that the tablet is seriously broken and help from a service professional is indeed necessary.
