How to Transfer Files from PC to Android Using WiFi
Want to transfer files from PC to Android via WiFi but don’t know how? Here in this article, we’ll show you an easy and safe method to make it.
Author Avatar Joy Taylor Last Updated: Aug. 23, 2024
Transferring files from PC to Android has never been a complex task for most users, for example, you can just plug your Android phone into the PC via a USB cable and then a few seconds later you can manage your Android files on PC with ease. But there are also some potential risks while using USB cable like unstable connection, USB port broken and so on. In addition, what if you just don’t have a USB cable available when you want to transfer files from PC to Android?
At this time, transferring files from PC to Android via WiFi is an option to go. For this purpose, AnyTrans for Android is strongly recommended for you to make it with ease. Within several simple steps, you can use WiFi to move your files from PC to Android direct without connecting to computer with a USB cable.
The Tool You’ll Need – AnyTrans for Android
Developed as a comprehensive Android data management tool, AnyTrans for Android has helped millions of users manage their Android files in an easy and effective way. Here let’s check some main features of this tool:
  1. Supports transferring files from PC to Android via WFi easily as long as your Android device and computer were connected to the same WiFi network.
  2. Supports transferring Android files like photos, contacts, music, videos, TV shows, audiobooks, calendars, messages and more.
  3. Allows you to transfer files from Android to computer, from computer to Android and from Android to Android within steps.
  4. It’s compatible with common Android devices like Sony, Samsung, Huawei, HTC. LG and works well on both Windows and Mac computer.
How to Transfer Files from PC to Android via WiFi
Before the start, you need to free download AnyTrans for Android to your PC and then follow the steps below to transfer files from PC to Android using WiFi.
Step 1: Run AnyTrans for Android on your PC and then free download AnyTrans on your Android phone. You can get it via https://anytrans.site/ or Google Play.
Step 2: Make sure your PC and Android are connected to the same WiFi network and then scan the QR on the PC with your AnyTrans app on an Android phone.
Step 3: Then select the files you want to transfer from your PC and click on To Device button to start moving files from PC to Android using WiFi.
That all about how to transfer files from PC to Android via WiFi with the help of AnyTrans for Android. What’s more, you can also connect your Android device to PC with a USB cable to manage your Android data with ease. Now just get it to your computer and have a free trial >
