DFT Pro Tool Review 2026: A Pro’s Guide for Huawei Repairs
A 2026 review of DFT Pro Tool for professional technicians. We analyze its price, dongle, and its unmatched strength in Huawei and HarmonyOS repairs, comparing it to its top competitors.
Author Avatar Roger Smith Last Updated: Feb. 27, 2026
For professional repair technicians, choosing the right mobile repair software is a critical business decision. The market is crowded, and the fear of investing in a tool that doesn’t deliver real-world results is a major obstacle. Too many guides stop short of the most difficult steps, leaving you stuck mid-repair.
This DFT Pro Tool review 2026 is different. It’s written for business-minded technicians who need to know if this tool will expand service capabilities and increase shop revenue. Our analysis covers its core features, a hands-on Huawei ID removal walkthrough, supported functions, pricing, and how it stacks up against competitors like UnlockTool and Chimera.
The central question: Will DFT Pro Tool make your repair shop more profitable?
What is DFT Pro Tool?
DFT Pro Tool is a specialized mobile repair software designed for professional technicians, with a focus on Huawei and HarmonyOS devices. It excels in complex tasks like Huawei ID removal, FRP bypass, and bootloader unlocking, particularly for Kirin chipsets. Supporting a range of brands (e.g., Xiaomi, Oppo, Samsung), it’s best known for first-to-market solutions for Huawei’s latest security patches, making it a go-to for high-margin repairs. The tool offers a user-friendly interface, real-time logs, and both digital and dongle-based licensing for flexibility.
Primary Strength: Unmatched for Huawei/HarmonyOS repairs, especially Huawei ID removal on the latest security patches.
Best For: Shops aiming to dominate the local Huawei repair market with high-margin services.
Cost Model: Flexible with a digital license (~$80-$100) or portable USB dongle (~$130-$160).
Competitors: UnlockTool for multi-brand versatility, Chimera Tool for Samsung KG lock expertise.
DFT Pro Tool Supported Models & MTK Functions
DFT Pro Tool Supported Models List
  • Strong support for Huawei Mate / P series with Kirin 9000/9000s chipsets.
  • Growing list of HarmonyOS-enabled devices.
DFT Pro Tool MTK Functions
The tool provides solid DFT pro tool mtk functions, including Read/Write Firmware, FRP Reset, Bootloader Unlock/Relock, and IMEI Unlock.
DFT Pro Tool Activation Price and License Types
The dft pro tool activation price depends on the license type, offering different levels of cost and flexibility.
  • Digital License (1-Year): Typically ranges from $80 to $100 USD. It is locked to a single PC’s hardware ID. This is a great lower-cost entry point
  • DFT Pro Dongle: Often priced between $130 to $160 USD. The dft pro dongle is a physical USB key that holds your license, allowing you to use the software on any computer. This portability is essential for technicians with multiple workstations.
DFT Pro Tool vs UnlockTool vs Chimera: A 2026 Comparison
Selecting the best GSM tool depends on your shop’s focus. This table compares DFT Pro Tool, UnlockTool, and Chimera Tool to highlight their business value for 2026.
Feature / Scenario DFT Pro Tool UnlockTool Chimera Tool
Primary Strength Huawei / HarmonyOS Specialist Broad Multi-Brand Support Samsung & BlackBerry Specialist
Huawei ID Remove Excellent, often first-to-market Good, but may lag on new patches Limited Support
Samsung KG Lock Basic/Moderate Support Moderate Support Excellent, Industry Standard
Broad MTK/Qualcomm Good, strong MTK functions Excellent, vast model list Good, but more specialized
Update Frequency Focused on Huawei/Security Very Frequent, broad updates Frequent, focused on Samsung
Best For… Shops specializing in Huawei High-volume, multi-brand shops Shops specializing in Samsung
How to Choose for Your Shop:
  • Choose DFT Pro: If you want to be the go-to expert for Huawei repair software in 2026, especially for Kirin chipsets and HarmonyOS. Its timely updates for complex procedures give you an edge in high-margin Huawei ID removals.
  • Choose UnlockTool: Ideal for general shops handling Xiaomi, Oppo, Vivo, and more. It offers the best ROI for diverse, high-volume repairs.
  • Choose Chimera Tool: Perfect if Samsung devices (especially Knox Guard locks) drive your revenue.
How to Use DFT Pro Tool
Theory is not enough. Here, we provide a concrete, step-by-step guide for removing a Huawei ID from a P40 Pro (Model ELS-NX9) using the test point method—a procedure that shows off DFT Pro’s core strength.
Pro Tip: Before beginning any motherboard-level work, ensure the device is fully powered off and the battery is disconnected to prevent accidental short circuits.
1. Prepare Tools: Gather fine-tipped tweezers, a USB-C cable, and a PC with DFT Pro installed. Install drivers (see Driver Guide).
2. Locate Test Point: Open the P40 Pro (use iFixit teardown guide for safety). Find the single gold test point on the motherboard near the SIM tray. Identify a nearby metal shield as the ground point.
3. Enter Service Mode: Gently touch one tweezer tip to the test point and the other to the ground. While holding, connect the USB-C cable to your PC.
4. Launch DFT Pro: Open DFT Pro, select the Huawei tab. Verify device detection in Windows Device Manager under “Ports (COM & LPT)” as “Huawei USB COM 1.0”.
Launch DET Pro Tool
Launch DET Pro Tool
5. Execute Removal: In the Service sub-tab, select Remove Huawei ID, choose Kirin 990 chipset, and click Start.
6. Monitor Progress: Watch the log window for real-time updates. Success shows “Operation Finished. OK” (typically 5-10 minutes).
Monitor the DET Log
Monitor the DET Log
❓Troubleshooting: If the device isn’t detected, recheck the test point connection or drivers. If the operation fails, ensure your license is active and check GSM forums for server status.
DFT Pro Tool Driver Guide: Fixing Connection Errors
Most failed operations trace back to incorrect drivers. This guide provides a verified process for a stable connection.
Verified Driver Installation
  • Disable Driver Signature Enforcement: Restart Windows in Advanced Startup Mode (Settings > Recovery > Restart Now) and disable enforcement to allow GSM drivers.
  • Install Base Drivers: Download and install Huawei HiSuite (official site) for core drivers.
  • Install DFT Pro Prerequisites: Run the DFT Pro installer as administrator, ensuring all libraries are selected.
  • Add Huawei USB COM 1.0 Driver: Find this in the DFT Pro installation folder (e.g., C:\DFTPro\SupportFiles).
Diagnosing in Device Manager
  • Connect the device and open Device Manager (Windows + X > Device Manager).
  • Look for a yellow exclamation mark (e.g., “Unknown Device”).
  • Right-click, select “Update driver,” and browse to the DFT Pro driver folder
Alternative Tool Recommendation: DroidKit for FRP and Huawei Repairs
For technicians seeking an alternative to DFT Pro, DroidKit (by iMobie) is a versatile option for FRP bypass and some Huawei repairs. Unlike DFT Pro Tool, DroidKit requires no root access and offers a streamlined, secure process with 256-bit SSL encryption. This guide details how to use DroidKit to remove FRP locks, perfect for technicians or advanced users seeking a reliable solution.
  • Ease of use: Designed with a guided, user-friendly workflow for FRP removal and unlock tasks; less manual setup than traditional GSM suites.
  • Cross-platform support: Public vendor materials show macOS and Windows installers, which broadens shop flexibility.
  • Broad device & Android version coverage: Advertised compatibility across many OEMs and Android versions (reports often list Android 6–15 coverage for unlock workflows).
  • Simpler setup and lower technical barrier: DroidKit is often recommended when technicians or customers need a fast, lower-risk path to regain access without deep chipset-level intervention.
Step-by-Step Instructions:
1. Download and Install DroidKit: Visit imobie.com and download the latest DroidKit version. Install it on your Windows or Mac computer, following the on-screen prompts. Ensure you select “Run as Administrator” on Windows to avoid permission issues.
2. Launch DroidKit and Select FRP Bypass: Open DroidKit and choose the FRP Bypass mode from the main interface. Click Start to begin.
Choose FRP Bypass
Choose FRP Bypass
3. Connect Your Device: Connect your FRP-locked Android device to the computer using a USB-C cable. Ensure USB debugging is enabled if prompted (follow on-screen instructions for your device brand).
Troubleshooting: If the device isn’t detected, try a different USB port or cable. Check Device Manager (Windows) or System Information (Mac) to confirm connection
4. Select Device Model and Prepare Configuration: DroidKit will prompt you to select your device brand and model (e.g., Samsung Galaxy Note 10+). Confirm the details, and DroidKit will generate a configuration file tailored to your device. Click Start to Bypass once ready.
Preparing the Configuration File
5. Enter Recovery Mode: Follow DroidKit’s on-screen instructions to put your device into Recovery Mode (e.g., for Samsung, hold Volume Up + Power until the logo appears). Select Reset in Recovery Mode to initiate the bypass process.
Go to Factory Mode
Go to Factory Mode
6. Complete the Bypass: DroidKit will process the FRP removal, displaying progress in the software. Once finished, you’ll see a confirmation screen (“FRP Bypass Complete”). Your device will reboot without the Google account lock, allowing you to set up a new account.
Post-Bypass Tips:
  • If the device doesn’t reboot automatically, manually restart it.
  • Verify the bypass by completing the setup wizard without Google account prompts.
  • If the process fails, check for DroidKit updates or consult iMobie’s support page for model-specific fixes.
DFT Pro Tool FAQ
Which tool is best for Samsung KG locks and Huawei HarmonyOS?
For Samsung KG locks, Chimera Tool is the industry standard. For complex jobs on Huawei HarmonyOS, including Huawei ID remove, DFT Pro Tool is the leading solution.
What are the unique functions of DFT Pro for Huawei/HarmonyOS?
DFT Pro often has first-to-market solutions for modifying OEMInfo, converting software regions (de-branding), and reliable FRP removal for new HarmonyOS security patches.
Where can I find official sources for USB drivers?
Always use official PC Suites (Smart Switch, HiSuite) or trusted reseller support pages.
How do I troubleshoot server connection or authentication errors?
First, temporarily disable your Firewall/Antivirus. Second, double-check your credentials. Third, check GSM forums for news on server maintenance.
How does official support for DFT Pro work?
Support is primarily handled by your reseller (for license issues) and the expert community on official forums like GSM-Forum.
Conclusion: Making the Right Investment for Your Business
The DFT Pro Tool proves its worth as a specialized instrument for any technician serious about servicing modern Huawei devices. For complex jobs on the latest Kirin chipsets running HarmonyOS, it is an indispensable and profitable asset that can set your shop apart from the competition.
However, it is not a one-size-fits-all solution. For general-purpose shops, a tool like UnlockTool may offer a better overall ROI. Your final decision must be driven by a clear analysis of the phones you see most often. By matching the tool’s strengths to your business needs, you can make a confident investment that directly contributes to your bottom line.
