Top 16 Tips to Save Battery on iPhone Xs/Xr/X/8/7/6s and New iPhone 11/11 Pro(Max)
Switch to New iPhone Basic Tips for New iPhone How to Restart iPhone iPhone Quick Start Not Working Set Up New iPhone What Is the Other on iPhone Trust A Developer on iPhone Change Passcode on iPhone Best Organizer App for iPhone How to Backup iPhone How to Clone an iPhone Time Spent on iPhone […]
Author Avatar Joy Taylor Last Updated: Apr. 21, 2022
AnyTrans – Full-way iPhone Photos Transfer Tool
Free download AnyTrans to 1-click to transfer all photos (Camera Roll, Photo Library, Photo Stream, and Albums) from iPhone to PC or Mac computer.
Nowadays, we rely on our smartphones just like we rely on oxygen and electronic products. Naturally, this makes us have a higher demand for the battery life of smartphones, and hope they can last longer between charges. However, they are just beautiful wishes. Most of us find our mobile phone and tablet battery draining fast, especially, iPhone and iPad.
Many users who upgraded to iOS 13 or just get a new iPhone 11 complain that their iPhone or iPad battery draining fast, even can’t make it through the day without charging. This issue can also happen to some users after updating to iOS 13/12/11/10 or on their new iPhone 11. Here we collect the top 16 iPhone iPad battery saving tips for you so that you can solve your iPhone iPad battery problems and make it last longer. And this post is suited for all the models of iPhone and iPad, including the old iPhone Xs/Xr/X/8/7/6s, and the new iPhone11 and iPhone 11 Pro (Max).
Before starting our iPhone iPad Battery Tips & Tricks, there is an important note for you: the idea isn’t to performing all of them on your iPhone iPad to boost its battery life, instead, it’s to start from a clean slate. So that you can figure out what had been draining the battery of your iPhone, iPad, and then follow our tips and tricks to bring your battery life back up to where you can get several days of standby, or at least get through a whole day without recharging.
Method 1: Check What Drains Your iPhone iPad’s Battery
When it comes to extending or improving battery on iPhone iPad, the first thing you need to do is checking what Apps drain your iPhone iPad battery most. For iOS 10/11 users, you can follow us with the steps below:
  1. On your iPhone iPad, launch the Settings App.
  2. Scroll down to tap on Battery.
  3. Scroll down to see which of your Apps were the biggest battery drainers in the past 24 hours, or the last 7 days.
You need to remember these iPhone or iPad battery drainers, and we will take them into consideration when performing some operations. For example, Facebook eats up nearly 33% battery of your iPhone, you can choose to close Facebook’s Background Refresh, or close its notification, etc.
Method 2: Enable Low Power Mode on Your iPhone
Enable Low Power Mode to Extend Battery on iPhone
If you are working with an iPhone 11/Xs/Xr/X/8/7/6s, and your iDevice is running with iOS 9 and later, you must have noticed that a nice function named Low Power Mode, which will be activated automatically when your iPhone’s battery reaches below 20% percent. When Low Power Mode is on, mail fetch, background app refresh, automatic downloads, and some visual effects will be turned off or reduced automatically. This will greatly increase battery life on your iPhone.
Although this function will be activated automatically, you also can turn it on manually when necessary to make your iPhone battery last longer. To activate Low Power Mode on your iPhone which is running with iOS 9/10/11/12/13:
Go to Settings > Battery > Tap it to turn on Low Power Mode.
Once the Low Power Mode is turned on, the battery percentage in the top right corner will be shown in yellow, just like the photo in the right shows. And this feature is only available on iPhones that are running with iOS 9/10/11/12/13, and the iPad doesn’t have this feature.
Method 3: Turn off Background Refresh for Apps You Don’t Use Frequently
Close Background App Refresh
In the post of How to Make iPhone Faster, we have mentioned that turning on background App Refresh can slow down your iPhone. Similarly, when it is enabled on your iPhone iPad, it also can make your iPhone or iPad battery drain fast. So you can turn it off to extend battery life on your iPhone iPad.
Follow us to close Background App Refresh on your iPhone: Go to Settings > General > Background App Refresh > Tap on the option to disallow all the Apps to refresh their contents when on Wi-Fi or Cellular. Or you also can keep it on, but close the Apps you don’t use frequently.
Method 4: Clean Up Junks Files on Your iPhone to Save Energy on iPhone/iPad
Remove Junks from iDevice to Boost Battery Life
The cache and off-line files include images, snapshots, video/audio media info, etc., which are created to speed up files access temporarily. But over time they may occupy over 1 Gigabyte space absurdly. Every time initiating an App, you have to wait for a long time to let it load these data. During that period of time, there more power has been consumed.
Therefore, we also recommend you an iPhone iPad cleaning tool – PhoneClean, which helps you remove all kinds of junks and unwanted files, like Indiscoverable junks (like user caches, photo caches, App leftovers), Internet junks, (like Safari Junks, Browsing Histories, Webmail caches), Personal and Sensitive data, (like Message, Call History, Contacts, Notes), and System Junks (like iOS Notifications, App leftovers, Active Apps), etc. Anyway, PhoneClean offers you a clean and fast iPhone iPad. Now download PhoneClean to clean up your iPhone iPad by following this how-to guide.
Method 5: Adjust Brightness on Your iPhone iPad to Extend Its Battery Life
Adjust Brightness to Save Battery on iPhone iPad
This feature adjusts your display’s brightness according to the lighting of your current environment. This keeps the display from being constantly at its brightest. So to improve your iPhone iPad battery life, you can choose to not give this power to your device since it may make the bad decision.
Follow us to adjust brightness on your iPhone/iPad with steps below:
  1. Run Settings App.
  2. Scroll down to tap on Display & Brightness
  3. Turn Off Auto-Brightness by clicking on its option.
  4. Adjust the brightness to the low level by swiping to left.
Method 6: Always Keep Background Clean to Preserve iPhone iPad Battery Life
Close Background Apps
Close apps you aren’t using, or at least some of them. iDevice like iPhone iPad does a decent job of not allowing all open apps to suck your battery, but keeping more than 10 open is never a good idea. Especially for the Apps that require the network connection, they are constantly updating and draining your battery.
To close background Apps on iPhone iPad, you can double-click the Home button to bring up all the apps running in the background, and then swipe upwards to close them.
By the way, if you don’t use some Apps, uninstall them from your iDevice. This can get more free space on your device, and it also can extend your devices’ battery life.
Method 7: Auto Lock Your iPhone iPad to Extend Its Battery Life
You know, when the screen of your iPhone iPad is on, you are consuming power. So make sure that your iDevice isn’t awake when you are not using it. If you want to maximize the battery life of your iPhone iPad, you can choose to set the Auto Lock to 1 minute.
Set Auto Lock on iPhone iPad: Settings > General > Auto Lock > Set your iPhone iPad to sleep after one minute of inactive.
Method 8: Turn Off Wi-Fi When You Are Not Using It
Most of us don’t have the habit of turning off Wi-Fi when we are not connected to a Wi-Fi network. This makes the Wi-Fi of your iPhone or iPad on, and it will hunt around for Wi-Fi networks it could join. Naturally, it will consume the battery. So close it when you are not using it to save batter life on your iDevice.
There are two ways you can use to close Wi-Fi on your iPhone iPad:
  1. Go to Settings > WLAN > Enable Ask to Join Networks on > Tap on WLAN to close it.
  2. Swipe up from the bottom of your iPhone or iPad screen to access Control Center > Tap on Wi-Fi icon to close it.
Method 9: Disable Location Services to Improve Your iPhone iPad Battery Life
iDevice Battery Tips & Tricks – Close Location Service
iPhone Location service allows your phone to know where you are and give you exact driving directions, give that information to apps that help you find restaurants, and more. But, like any service that sends data over a network, it needs battery power to work. If you’re not using Location Services, and don’t plan to use it right away, turn them off and save some power.
Turn off Location Service on your iPhone iPad with following steps:
  1. Run Settings Apps.
  2. Scroll down to tap on Privacy.
  3. Click Location Services, and then tap on its option to close it.
Method 10: Extend Your iDevice’s Battery Life by Setting Email Fetch to Manually
Check Email Manually to Save Energy on iPhone iPad
The less often your phone accesses a network, the less battery it uses. Save battery life by setting your phone to check your email accounts less often. Try checking every hour or manually, if you’re really serious about saving battery. Manual checks means you’ll never have email waiting for you on your phone, but you’ll also stave off the red battery icon.
Check Email Manually: Settings > Mail, Contacts, Calendars > Fetch New Data > Tap on the option of Push to close it.
Method 11: Upgrade Your iPhone to the Latest iOS Version
Normally every software update often includes bug fixes, and some of them may fix your iPhone iPad battery problem . So please ensure your iPhone or iPad is working with the latest iOS version. Apple has released iOS 13.3.1 with bug fixes and performance improvements, so you can update to iOS 13.3.1 now.
Method 12: Turn Off Vibrations to Save Battery Life on iPhone iPad
Turn Off Vibrations to Extend Battery Life on iPhone iPad
Believe it or not, vibration alerts can use up battery life more than anything else, especially if you get a lot of push notifications. They’re nice to have, but if you don’t mind turning them off, you’ll probably notice an improvement in battery life.
Turn off vibrations: Settings > Sounds > Close Vibrate on Rings and Vibrate on Silent by taping on their options.
Method 13: Keep Useful Stuff in Notification Only
Disable Apps' Notifications to Boost iPhone iPad's Battery
Disable Apps’ Notifications to Boost iPhone iPad’s Battery
Make sure “Push notifications” are notifications sent by third-party apps straight to your phone through Apple’s servers. When you have lots of them enabled, they can wear down your iPhone battery. If you don’t need your phone to constantly check for updates from, say, your Stocks app, or that new social network you never use anymore, turn off the app’s ability to send you notifications.
Disable Apps’ Notification on iDevice: Settings > Notifications > Select the Apps in the Include column > Close it by taping on the option of Allow Notifications.
When closing the notifications of the Apps on your iPhone iPad, you can consider the battery drainers firstly, like Facebook. Absolutely, you don’t have to do it. Because it means you will miss all the latest news about friend requirements, comments, or posts on your Facebook.
Method 14: Disable Bluetooth to Extend Your iDevice’s Battery
The Bluetooth function is not only useful with wireless headsets or earpieces but also for iPhone or iPad users to share data wirelessly. But it also drains the battery of your device. Turn off Bluetooth except when you’re using it.
Follow us to close Bluetooth on your iPhone iPad:
  1. Settings > Bluetooth > Close It.
  2. Swipe up from the bottom of your iPhone or iPad screen to access Control Center > Tap on Bluetooth icon to close it.
Method 15: Close Personal Hotspot to Preserve Battery Life on iPhone iPad
Personal Hotspot turns your iPhone or iPad into a wireless hotspot that broadcasts its cellular data to other devices. It is a quite useful feature, however, it also drains your device battery. This only applies if you use the iPhone’s Personal Hotspot feature to share your wireless data connection with other iPhone or iPad.
Disable Personal Hotspot: Go to Settings > Personal Hotspot > Tap on it to close it.
Method 16: Set Your iPhone iPad to Airplane Mode to Save Battery
If your iPhone is running out of battery but you have to keep it in use for a while, an exigent iPhone battery saving tip is to turn on Airplane Mode, which will suspend many of the device’s signal transmitting functions, including receive calls or use text messaging. Note that enabling Airplane Mode doesn’t mean the battery will stay forever since it still permits the use of other functions (e.g., games, built-in camera, MP3 player).
Turn on Airplane on iPhone iPad: Settings > Airplane Mode > Tap on it to close it.
Have you fixed your iPhone iPad battery problem after performing all the tips & tricks on your device? Does it get through the whole day without recharging? If you make it, don’t forget to share this useful guide with the Apple users around you.
By the way, when you are busy with collecting tips & tricks for saving battery on iPhone iPad, why don’t you take the opportunity to learn how to speed up your iPhone iPad, and how to free up space to get more available storage on iPhone. Absolutely, if you also own a MacBook, here is a post about how to extend MacBook’s Battery Life.
