“Is Mobitrix LockAway reliable for unlocking an iPhone?” Similar questions are raised by users on forums when looking for a safe tool to unlock an iPhone passcode. In this article, we’ll dive deep into Mobitrix LockAway’s review and its best alternatives.
Free download AnyUnlock to remove the screen lock on your iPhone without credentials. No technical skills are required, no viruses and malware to worry about!
Forgetting your iPhone passcode can be a frustrating experience. Whether it’s due to a locked device after too many failed attempts, a second-hand device, or just forgotten passwords, users often search for effective solutions to bypass the lock screen. Mobitrix LockAway is one such tool designed to remove iPhone screen locks without a passcode. However, some people doubt that it is the best option for this task. This post will explore Mobitrix LockAway in full aspects.
Mobitrix LockAway is a specialized iPhone unlocking tool that allows users to bypass various types of screen locks, including 4-digit/6-digit passcodes, Face ID, and Touch ID. This tool gives iPhone users a simpler choice to regain access to their devices without passcodes than taking them to the repair store. Except for screen unlocking, Mobitrix LockAway can also unlock Apple ID, bypass MDM on iOS devices, and unlock screen time passcode.
Mobitrix Lockaway Software
Pros:
Cons:
Yes, Mobitrix LockAway is generally safe to use. This tool does not make unauthorized changes to your device’s hardware or software. It employs official bypassing methods, ensuring the security of your device. However, like any third-party software, its safety depends on how it is used and where it is downloaded from. And if the unlocking process is interrupted, it could result in firmware corruption on your iPhone. So, make sure that you download Mobitrix LockAway from a dependable source and use it correctly.
No, Mobitrix LockAway is not free. The tool operates on a subscription model, with pricing tiers based on the duration of usage. It provides three models to choose from 1-Month License, 1-Year License, and Lifetime License. You can buy it according to your use frequency.
Yes, Mobitrix LockAway works for bypassing iPhone screen locks in most cases. Many users report success in unlocking their devices, but there are still some negative reviews showing that this tool failed to unlock their iPhone screen. The success of unlocking is likely up to compatibility, or its success rate may not be so high.
Mobitrix LockAway is indeed a practical method to unlock your iPhone Passcode. It is safe and legitimate to use, but you should make sure you download the official software. If you decide to use Mobitrix LockAway to remove your screen lock, here are steps to unlocking your iPhone using this tool:
Step 1. Download Mobitrix LockAway from the official website and install it on your computer.
Step 2. Open Mobitrix LockAway and select the “Unlock Screen Passcode” option.
Choose “Unlock Screen Passcode” Option
Step 3. Use a USB cable to connect your iPhone to the computer.
Step 4. Follow the on-screen instructions to put your iPhone in Recovery Mode.
Enter Recovery Mode on iPhone
Step 5. After the Keyfile is detected, you will be asked to download the Keyfile package for your device. Click the Download button.
Download Suitable Keyfile Version
Step 6. Once the firmware is downloaded, click “Start Unlock” to remove the screen lock. After the process is completed, screen unlock is successful.
Remove Screen Lock on iPhone
If you’re looking for a simpler, more reliable solution, AnyUnlock is an excellent alternative to Mobitrix LockAway. As a powerful iPhone unlocker, AnyUnlock can help you remove screen locks on iPhones with a few clicks. Compatible with both Windows and Mac, it supports unlocking all types of passcodes. Among numerous competitors, the software stands out for its easy steps and high success rate in unlocking iPhones. Guaranteed 100% safety and cleanness of AnyUnlock, users don’t need to worry about viruses and malware.
Main Benefits of AnyUnlock:
Here is stepwise guidance on how to unlock iPhone with AnyUnlock:
Step 1. Free download AnyUnlock and run it on your PC > Connect your iPhone to the PC > Choose Unlock Screen Passcode mode.
Step 2. Download the firmware package and tap on the Unlock Now option.
Click Unlock Now to Remove Screen Passcode
Step 3. Waiting for the process to be completed, you will see the Screen passcode removed successfully interface.
Successfully Removed Screen Time Passcode
In conclusion, Mobitrix LockAway is a dependable tool for unlocking iPhone screens, but it still contains limitations like data loss and unsure success rate. For users seeking a simpler and safer alternative, AnyUnlock stands out with its high success rate and versatile features. With the help of AnyUnlock, users can remove screen locks on iPhones in 3 simple steps. Free download AnyUnlock Now!
