How to Bypass FRP on Android 14: Samsung, APK & PC Methods
Android 14 FRP is not one universal bypass process. Samsung Test Mode, FRPFile/APK routes and PC tools all depend on the device brand, build and security patch. This guide shows which checkpoint to verify first and when a method does not match your phone.
Author Avatar Joy Taylor Last Updated: Aug. 19, 2026
Android 14 FRP is not one universal bypass process. A Samsung route built around *#0*# Test Mode does not apply to Pixel, Motorola, Xiaomi, OPPO, or every other Android 14 phone, and even two devices from the same brand can expose different setup screens after firmware or security updates.
The useful question is therefore not simply “Which Android 14 FRP bypass works?” Start with the phone brand, current build, and the first entry point required by the method you found. If Samsung Test Mode does not open, an FRPFile APK cannot reach its installer, or a PC tool does not list your brand or current software scenario, that route is not a match for the phone in front of you.
For Android-wide FRP concepts and brand navigation, use the Android FRP bypass guide. If you are deciding between commercial and free software rather than looking for one Android 14 shortcut, the FRP bypass tool comparison is the better place to compare products.
Android 14 checkpoint: Follow FRP recovery or removal instructions only for a phone you own or are authorized to service. A missing Test Mode, browser redirect, APK installer, or tool-supported route is a reason to stop that method—not a reason to keep forcing the same sequence.
Quick Answer: Start with Brand + Build
If the phone still accepts a Google Account that was previously added and synced to it, use that account first. When account recovery is not available, identify the brand and then check whether the method’s first required screen actually exists.
Your Android 14 Situation First Check What the Result Means
You know a previously synced Google account Sign in or recover the account This follows Android’s ownership-verification path without relying on a setup shortcut.
Samsung and the guide requires *#0*# Check whether the diagnostic/Test Mode screen actually opens If it does not open, do not continue with a route that depends on Test Mode.
FRPFile or another APK is required Check whether you can reach a browser/file source and the Install unknown apps control If setup does not expose those controls, the APK route cannot proceed as written.
You want to use DroidKit Check the current supported-brand list and Samsung patch restriction first Do not assume every Android 14 phone is eligible just because the software supports Android FRP.
Google Pixel Start with Google account recovery and Pixel-specific guidance The current DroidKit FRP Guide does not list Pixel in its supported device-brand list.
Another Android 14 brand Use brand-specific setup and tool guidance Samsung diagnostic codes and Samsung screenshots should not be transferred to another OEM.
Which Android 14 FRP Route Fits Your Phone?
Use this table to eliminate routes that do not match your device before spending time on detailed steps.
Route What Must Be Available PC Needed? Stop When
Google account verification A previously synced Google account or a valid account-recovery route No The account cannot be identified or recovered.
Samsung Test Mode route A Samsung device where the required diagnostic/Test Mode entry is accessible during the setup flow Depends on the specific method *#0*# does not open the required screen or the next step is absent.
FRPFile / APK route Browser or file access plus permission to install from that source Usually no The installer cannot open, permission is unavailable, or the APK is incompatible.
DroidKit FRP route A currently listed brand, applicable device route, stable USB connection, and supported Samsung patch when relevant Yes The brand/device is not supported or the Samsung patch falls under the current restriction.
Other brand-specific route The exact OEM setup screen and Android 14 build used by that guide Varies The tutorial switches to Samsung-only menus, codes, or tools that your brand does not have.
Why Android 14 FRP Routes Differ by Brand and Security Patch
Android 14 is an important compatibility checkpoint, but the major Android version is only part of the picture. Samsung One UI, Xiaomi HyperOS/MIUI, OPPO ColorOS, Motorola software, Pixel Android, and other OEM setup environments expose different menus and connection paths.
That matters because most manual FRP tutorials depend on a chain of entry points rather than on Android 14 itself.
Entry Point What to Verify on Android 14 Why a Tutorial May Stop
TalkBack / Accessibility Does the same accessibility shortcut and next menu exist? The OEM setup flow or current build may expose different options.
Samsung diagnostic/Test Mode Does *#0*# actually open the screen required by that Samsung-specific route? Availability can differ by Samsung model, build, region, carrier configuration, or setup state.
Browser or share redirect Can setup hand off to the browser or external app expected by the guide? The current Setup Wizard may not expose that handoff.
APK installation Can the required source reach the Install unknown apps permission and installer? Without source permission and installer access, the APK cannot run.
PC communication Does the tool list the brand/device and detect the phone in the required mode? Unsupported brand, driver, USB mode, cable, or tool-version differences can stop the workflow.
If the locked device is actually running another Android generation, use the corresponding version guide instead: Android 13 FRP bypass, Android 12 FRP bypass, or Android 11 FRP bypass.
Before You Try an Android 14 FRP Route
Google’s Android device-protection guidance provides the baseline for what you are seeing after reset. A protected device can require the screen lock or a Google Account previously added and synced to the phone, especially after a reset performed outside the normal Settings flow.
Before choosing a bypass route:
  • Try the previous account first: if you can identify and recover a Google Account previously synced to the phone, use it during setup.
  • For a second-hand phone: ask the seller to resolve the previous account before trying third-party tools.
  • Check the exact brand: Android 14 does not make Samsung, Pixel, Xiaomi, OPPO, and Motorola setup flows identical.
  • Check the current build and security patch: these details can affect a route even when two devices both say Android 14.
  • Separate FRP from SIM lock: Google account verification after reset is not the same as carrier/network unlocking.
If you still have normal access to an Android 14 phone before selling or resetting it, Google’s documented way to turn off device protection includes removing the Google Account from the device. See Google’s device protection guidance before resetting a phone for another owner.
Method 1. Samsung Android 14: Check Whether Test Mode Is Available
Samsung is the main brand on this page where *#0*# appears in FRP searches. The code is associated with Samsung diagnostic/Test Mode on compatible Galaxy devices, but its availability should be treated as a Samsung-specific checkpoint—not as proof that FRP is removable or that a particular bypass tool will work.
Step 1. Check the Samsung Test Mode Entry
Step 1. On the Samsung Android 14 setup screen, connect the phone to Wi-Fi if the setup process requires a connection.
Step 2. Open Emergency Call only if the Test Mode-dependent instructions you are evaluating require the dialer.
Tap Emergency Call on a Samsung setup screen
Open the Emergency Call Screen
Step 3. Enter *#0*#.
Enter the Samsung diagnostic Test Mode code
Check Whether Samsung Test Mode Opens
Step 4. If the diagnostic/Test Mode screen does not open, stop any FRP method whose next step depends on that screen.
What *#0*# tells you: it can tell you whether that Test Mode-dependent route is available in the current Samsung setup environment. It does not by itself tell you why the screen is unavailable, whether FRP has been patched, or whether a particular PC tool supports your security patch.
What to Check Before Continuing from Test Mode
If Test Mode does open, do not jump directly from “the code worked” to “FRP can be removed.” Check the exact Samsung model, One UI/build information available to you, and the requirements of the specific method or tool you plan to use.
This matters especially for DroidKit: its current FRP Guide states that Samsung devices with security patches dated August 2023 or later are currently unable to bypass FRP with that feature. Therefore, Test Mode opening does not override the tool’s current Samsung patch restriction.
For Samsung-only alternatives and model routing, use the Samsung FRP bypass guide.
Method 2. FRPFile / APK on Android 14: Required Checkpoints
Searches for FRPFile bypass Android 14, Android 14 FRP APK, or similar APK routes usually depend on several separate permissions and setup-screen transitions. The APK filename alone does not tell you whether the route can work.
APK Checkpoint What You Need Failure Signal
Browser / download access A setup route that can reach the file source The browser, share sheet, or download page cannot be opened.
File access A file manager or installer can access the downloaded APK The file is downloaded but cannot be opened from setup.
Install unknown apps permission Permission for the specific source that is attempting the installation The setup environment does not expose the permission screen.
Package compatibility An APK compatible with the current Android/device environment “App not installed,” package errors, immediate crashes, or missing required screens.
File trust A source you can identify and evaluate Unknown mirror, fake download buttons, modified packages, or requests to disable security software.
Android has required user opt-in for apps from unknown sources on Android 8.0 and later, with permission granted for the relevant source. The practical Android 14 question is whether the locked setup environment actually lets you reach that permission and installer—not whether Android 14 invented sideload protection.
If you are evaluating an FRPFile-style download, read the FRP bypass APK safety guide before installing a package from an unfamiliar site.
Method 3. Check a PC-Based Android 14 FRP Tool
A PC tool is useful only when its current compatibility information matches the phone. Do not switch automatically from a blocked Samsung Test Mode route to a desktop program without checking the vendor’s supported brands, model route, and any security-patch restrictions.
DroidKit Android 14 Compatibility Check
DroidKit’s current FRP Guide lists the following device families for its FRP feature: Samsung, Xiaomi, OPPO, Motorola, Lenovo, VIVO, Redmi, POCO, Realme, SONY, and OnePlus, running Android 6 and above. The same guide currently states that Samsung security patches dated August 2023 or later are unable to use its FRP bypass feature.
Android 14 Brand / Situation DroidKit Check What to Do
Samsung with security patch August 2023 or later Current DroidKit FRP Guide lists this as unsupported for FRP bypass Do not present DroidKit as the Samsung solution for that patch; use Samsung-specific alternatives or account recovery.
Samsung with another applicable environment Check the current Guide and the exact device route before starting Test Mode availability alone is not enough to confirm support.
Xiaomi / Redmi / POCO These brands are currently listed by DroidKit Confirm the exact connected-device route and follow the current software instructions.
OPPO / OnePlus Both are currently listed Check the ColorOS/OxygenOS-specific route shown by the tool.
Motorola / Lenovo / VIVO / Realme / SONY Currently listed brand families Confirm device detection and the route provided for the connected phone.
Google Pixel Pixel is not in the current DroidKit FRP supported-brand list Do not assume DroidKit compatibility; use Google account recovery or Pixel-specific options.
Do the compatibility check before downloading for this specific FRP case. “Android 14” by itself is not a supported-device claim. The phone brand, current tool documentation, Samsung patch date when relevant, and route shown for the device all matter.
How to Use DroidKit After You Confirm Compatibility
Step 1. Download and install DroidKit on a Windows PC or Mac only after confirming that the phone belongs to a currently supported FRP brand and does not fall under a documented restriction.
Step 2. Open DroidKit and choose FRP Bypass.
Choose FRP Bypass in DroidKit after checking device compatibility
Choose FRP Bypass After Checking Compatibility
Step 3. Connect the Android 14 phone with a reliable USB data cable and let the software identify the available brand/device route.
Step 4. Follow only the instructions displayed for the connected phone. Brand-specific steps can differ, and Samsung instructions should not be substituted for Xiaomi, OPPO, Motorola, or another listed brand.
Step 5. Keep the device connected while the selected workflow is running. If the software reports that the phone or route is unsupported, stop rather than trying to force a different brand profile.
Android 14 FRP Notes by Brand
This brand table is the reason an Android 14 version guide should not recommend one route for every phone.
Brand / Family Android 14 Checkpoint Recommended Direction
Samsung Confirm the One UI/build, whether a Test Mode-dependent route is actually available, and the security patch if considering DroidKit Use Samsung-specific guidance; do not equate *#0*# opening with guaranteed FRP-tool support.
Google Pixel Do not apply Samsung Test Mode instructions or assume DroidKit support Start with Google account recovery and Pixel-specific guidance.
Xiaomi / Redmi / POCO Check the Xiaomi/HyperOS or MIUI setup path rather than Samsung menus Use Xiaomi-specific guidance or a PC tool whose current documentation lists the applicable brand/device.
OPPO / OnePlus Check the current ColorOS/OxygenOS route and the exact tool workflow Do not use Samsung diagnostic codes as a compatibility test.
Motorola Check Motorola-specific setup entry points and current Android build Use Motorola guidance rather than APK or Test Mode instructions copied from Samsung.
VIVO / Realme / Lenovo / SONY Verify the current device route before using desktop software These brands appear in the current DroidKit FRP list, but exact device instructions still need to match.
Android 14 FRP Bypass Not Working? Diagnose the Failure
The failed checkpoint usually tells you more than the name of the tutorial. Identify where the route stops before switching methods.
Problem What It Means What to Check Next
*#0*# does not open Test Mode The Samsung Test Mode-dependent route is unavailable in the current setup Do not continue with steps that require that screen; check Samsung-specific alternatives.
FRP APK cannot be installed Browser/file access, source permission, package compatibility, or installer access is missing Identify which checkpoint failed before downloading another APK.
Browser/share redirect immediately closes The current setup environment does not expose the required handoff Stop the browser-based route and use another brand/build-specific option.
DroidKit shows an unsupported Samsung situation The Samsung patch/device falls outside the current FRP route Do not keep retrying with a different Samsung profile; use another applicable solution.
DroidKit does not list Google Pixel Pixel is outside the current official DroidKit FRP brand list Use Google account recovery or Pixel-specific guidance.
PC does not detect the phone Cable, driver, USB port, mode, or unsupported device can be the issue Resolve device detection before judging whether the FRP process itself works.
Google verification returns after another reset The ownership-verification requirement remains active Use a previously synced Google Account, seller assistance, or another applicable recovery route.
If several different tutorials fail at the same type of entry point, the FRP bypass not working guide can help separate a missing setup route from a tool, driver, or account problem.
FAQs About Android 14 FRP Bypass
Can Android 14 FRP bypass be done without a PC?
Only when the phone’s brand and current setup build still expose every entry point required by the no-PC route. On Samsung that may involve a Test Mode-dependent path; an APK route needs browser or file access plus permission to install from that source. If the required screen is absent, that no-PC method cannot continue as written.
Does *#0*# prove my Samsung Android 14 FRP method will work?
No. *#0*# is associated with Samsung diagnostic/Test Mode on compatible devices. If it opens, it only confirms that this screen is available in the current setup environment. It does not confirm that FRP can be removed or that a specific PC tool supports the phone’s security patch.
Does FRPFile bypass Android 14 still work?
An FRPFile-style APK route requires several checkpoints: access to the file source, a way to open the APK, permission for that source to install unknown apps, and package compatibility. If Android 14 setup blocks any one of those checkpoints, the APK cannot complete that route.
Does Android 14 itself block unknown APK installation?
Android has required user opt-in for apps from unknown sources since before Android 14. On Android 8.0 and later, permission is granted for the particular source. For FRP tutorials, the key issue is whether the locked setup environment lets you reach that permission and installer.
Does DroidKit support Samsung Android 14 FRP?
Check the Samsung security patch before assuming support. DroidKit’s current FRP Guide states that Samsung devices with security patches dated August 2023 or later are currently unable to use its FRP bypass feature. Test Mode opening does not override that documented restriction.
Does DroidKit support Google Pixel FRP on Android 14?
Google Pixel is not included in the current DroidKit FRP supported-brand list. Do not infer Pixel support from a general “Android FRP” description; use Google account recovery or a Pixel-specific route instead.
Will another factory reset remove Android 14 FRP?
Not automatically. Android device protection can require a screen lock or a Google Account previously added and synced to the device after a protected reset. Repeating the reset does not by itself satisfy that ownership verification.
How can I avoid FRP before resetting an Android 14 phone?
If you still have normal access and are preparing the phone for another owner, confirm your account credentials and remove the Google Account from the device before the reset. Google’s device-protection documentation identifies account removal as a way to turn off device protection.
Android 14 FRP Is a Compatibility Decision
The most useful Android 14 FRP check is the first dependency of the route you are considering. On Samsung, determine whether the Test Mode screen required by that method exists—but do not mistake *#0*# for a universal FRP compatibility test. For FRPFile and other APK methods, check browser/file access, source permission, installer availability, and package compatibility before trusting the filename.
PC tools need the same discipline. DroidKit currently lists several Android brands, but it also documents a specific Samsung security-patch restriction and does not list Pixel. Match the tool to the actual phone before treating it as the next step. Android 14 tells you the software generation; the brand, build, patch, and available entry point decide which route is actually relevant.
