Bought a phone locked with a network carrier and don’t know how to unlock it? Follow this guide to know how to unlock a network locked phone for free.
If you have bought a new phone that is locked with a particular network or have bought a second-hand phone but haven’t checked iPhone’s lock status properly before buying, then you are bound to use the same network.
A company network locks a phone while selling it under discounts or offers. You can use a different network SIM in the same phone by unlocking the phone with the help of the previous network provider company.
If you want to unlock a phone but don’t know how to do so. Then, here, in this content, we will discuss how to unlock a network locked phone for free. Read this content till the end to get 2 proven solutions.
Yes! You can network unlock a phone for free. It is entirely free to unlock your phone if you are qualified. If you are an existing user of the same network provider with which your phone is locked, then it can be free for you. Non-customers and past customers may be charged a price to unlock eligible devices.
If you are not an existing user of the same network, then here we will tell you how to unlock a network locked phone for free.
Generally, the first method that people opt for is contacting their network provider as they can provide the best assistance for how to unlock a network locked phone for free.
Now that you are aware of the restrictions and have all of the necessary information, take the procedures outlined below to unlock your phone straight through the carrier.
The unlock code and instructions on how to input the code will be given to you within 30 days.
You may unlock network lock by yourself without SIM network unlock PIN or IMEI number. AnyUnlock — iPhone Unlocker is a third-party program that can unlock any SIM card easily on your own.
AnyUnlock – iPhone Password Unlocker can be used to unlock network locked phones for free. You may use it to unlock any sort of SIM card, including AT&T, Vodacom, Sprint, T-Mobile, Verizon, and others. You may use AnyUnlock to unlock your SIM network without having to contact the network provider firm. There will be no data loss, and your information will be secure.
These steps will help to know how to unlock a network locked phone for free.
Step 1. Run AnyUnlock when it has been downloaded and installed on your computer. On the Remove SIM Lock screen, choose the Start Now option.
Step 2. Connect your iPhone to your computer using a lightning USB cable. Then the information and jailbreaking status of your iPhone will display on the next screen. If you see the following interface, right-click Remove Now to continue. If you don’t, follow the on-screen steps to jailbreak your iDevice.
Step 3. Follow the instructions below to pull out the SIM card and disconnect the Internet from your device.
Step 4. AnyUnlock will instantly unlock your SIM network when you finish the corresponding settings.
Step 5. You can now disconnect your smartphone and use it with any network provider when the process is done.
There are various ways to monitor the status of your iPhone’s unlocking. To check that, first place a new SIM with different network carrier on your phone. Open the dial pad and make a call to someone else. After that, if you are able to make a call, your phone is unlocked.
The second technique is to look for the cellular network that corresponds to your current carrier on your phone. Alternatively, we may use the cellular option that is available in the settings. As a result, we can be certain that our existing carrier will not lock out the device at that time.
Follow the below-given steps to check the network unlock option in the Settings:
Go to the Settings app > Click on Mobile Data > If your phone displays an option of ‘Mobile Data Options’, it indicates your phone is network unlocked. If you do not see the option, it indicates that your phone is locked.
No. Unlocking your device strictly removes the software limitation that restricts it to a single carrier’s frequency bands. It does not alter the processor speed, camera quality, or memory. Once you unlock a network locked phone, the device functions exactly as it did before.
Generally, no. In the US (and many other regions), unlocking a cell phone for the purpose of switching carriers is a protected consumer right. When you request a code directly from your carrier, it is an official process that keeps your hardware warranty intact. However, note that “rooting” (Android) or “jailbreaking” (iPhone) to achieve an unlock can void warranties, so stick to the official carrier method whenever possible.
Usually, no. Carriers enforce the lock to ensure the device is paid for. You must meet the financial obligations (pay off the phone) before they will authorize the release.
Exception: Active military personnel deployed internationally can often get an expedite international roaming unlock by submitting their deployment papers to the carrier’s specialized military support team.
A locked phone is a frustrating barrier, but for 90% of users, the solution is free and just a few clicks away.
We hope that the above-mentioned ways should help you to know how to unlock a network locked phone for free. We recommend you to use AnyUnlock – iPhone Password Unlocker to unlock a network locked phone in just a few simple steps. This is one of the best ways to unlocking a network locked phone.
