Screen mirroring iPhone enables you to display your iPhone’s screen on another device, such as a TV, PC, Mac, or even a car screen. Read this article to explore different methods or technologies available for screen mirroring your iPhone.
Today, screens have taken over the world, mobile phones, digital billboards, laptops, TVs, and more and more cars even have a small touch screen on the dashboard. As screens gradually become an important role in daily life, it is common to share content from one device to another by screen mirroring. Screen mirroring is incredibly useful in various situations, from delivering presentations at work or school to streaming your favorite shows or movies, playing mobile games on a larger screen, or navigating with your car’s built-in display.
Screen Mirroring iPhone
This guide here is about screen mirroring iPhone. It will tell you the compatibility and requirements of mirror iPhone screens, then walk you through the different methods for screen mirroring your iPhone to various devices, including TVs, PCs, Macs, and car screens, and tips to optimize your screen mirroring experience. Keep reading and see how to mirror iPhone to various devices.
Apple has developed a wireless screen mirroring feature for iPhone, iPad, and Mac called AirPlay, it lets you share your device’s screen with a TV or Mac or just use the iPad as the second screen easily. Any iPhone, iPad, or iPod Touch running iOS 4.2 or newer will have AirPlay built-in, you can take it as all iPhones and iPads have screen mirroring features. So if you wonder “Can I mirror my iPhone screen” in 2023, the answer is 100% yes!
Now you’ve known your iPhone is compatible with screen mirroring. The following sections will provide you with detailed instructions for each method, telling you how to mirror iPhone to other devices. Keep reading!
As mentioned above, iPhone users can rely on AirPlay to share iPhone screens with TV. Apart from Apple’s Apple TV, most TVs are now compatible with the AirPlay protocol. There is a valid record that all Samsung, Sony, and LG TVs support AirPlay.
Here is the guide on how to mirror iPhone to TV using AirPlay:
Step 1. Make sure the TV and your iPhone are connected to the same Wi-Fi.
Step 2. Open iPhone Control Center, and tap the screen mirroring icon.
Step 3. Select your TV from the list, and wait for a few seconds, you might be able to see your iPhone screen on the TV.
How to Turn On AirPlay
As you can see, it only takes three simple steps to screen mirror iPhone to TV via AirPlay. This method is both convenient and accessible when you want to display iPhone videos, music, or pictures on a TV screen. But there is also a drawback to this method. It primarily works with Apple devices or smart TVs that support AirPlay 2. If you have a TV that doesn’t support AirPlay 2, you’ll need to use alternative methods to enable screen mirroring.
Also Read: Best AirPlay Alternative for Screen Mirroring >
In recent years, smart TVs like Roku, Chromecast & Amazon Firesticks have become more and more popular. They are streaming video players, which means they stream video content over the Internet to your home, in real time. While they do not natively support iPhone screen mirroring, you can use the Roku app to achieve a similar effect. Here’s how to screen mirror your iPhone to a Roku device:
Step 1. On Roku, head into Settings > System > Screen mirroring > Screen mirroring mode and tap on Always allow.
Enable Screen Mirroring on Roku
Step 2. Launch App Store on your iPhone and install the Roku app on your device.
Step 3. Launch the Roku app on your device, tap on your Roku device in the list, and finally select Photos+ at the bottom.
Access the Photos+ Section in the Roku App
Step 4. You can now select the content that you want to mirror from your iPhone to Roku.
While mirroring your iPhone screen to a TV is great for entertainment purposes, there are times when you need to share your iPhone screen with a PC for free. For example, you may want to demonstrate an app during a presentation or record your iPhone screen using desktop software. There are no built-in features for iPhone to mirror the screen to a computer, so you need to use third-party software to help. Here are some popular options:
AnyMiro is a light and easy tool for screen mirroring. It allows you to mirror your iPhone on Mac/PC with a few clicks and no technical requirements. Here are the reasons why you should choose AnyMiro:
Follow the guide here to see how to mirror iPhone to PC with AnyMiro, both video guide and text guide are available:
Step 1. Download and run AnyMiro on your computer.
Step 2. Select mirror iPhone/iPad to enter iPhone mirroring.
Mirror iPhone to Computer
Step 3. Connect your iPhone to PC with a lightning cable.
Mirror iOS Device to Computer via USB
Step 4. Tap “Trust” on your iPhone, and wait a few seconds, you can see the iPhone screen on the computer.
Trust Your Computer on iPhone
If you are a PC user, you do not have AirPlay support for your computer. However, there are apps in the market that will let you add this missing support to your machine. Once it is added, you will be able to do screen mirroring from the iPhone to your PC. Here is how:
Step 1. Download and install the X-Mirage app on your Windows PC.
Step 2. Launch the app so it can set things up. You do not need to manually modify anything in it.
Step 3. Connect both your iPhone and your PC to the same WiFi network. Then, open Control Center on your iPhone, tap on AirPlay and select X-Mirage from the list.
Select X-Mirage as the AirPlay Receiver on iPhone
You are all set. Thanks to third-party screen mirroring apps, iPhone screen mirroring to PC has become easier and more efficient than ever.
While the methods mentioned above for mirroring your iPhone screen to a PC are also applicable to Mac computers, it’s worth noting that Macs with macOS 11 and earlier do not have built-in AirPlay support. As a result, Mac users may need to rely on third-party software to achieve screen mirroring. In this section, we’ll explore two ways to screen mirror your iPhone to a Mac: using a built-in tool for Macs running macOS 12 or later, and using third-party software for those with macOS 11 or earlier.
For Macs Running macOS 12 or Later:
The best way to mirror iPhone to Mac is to use AirPlay. The process is really simple, it is basically the same as how to AirPlay iPhone to TV. Make sure your Mac and your iPhone are connected to the same Wi-Fi. Open Control Center on your iPhone, tap the screen mirroring icon and select your Mac from the list.
For Macs Running macOS 11 or Earlier:
Back in the days when Mac did not have AirPlay support, users tend to use QuickTime Player to mirror iPhone to Mac. In this way, you don’t need to install any apps and it also doesn’t require a WiFi network connection. Here are the steps of screen mirroring iPhone to Mac with QuickTime Player.
Step 1. Connect your iPhone to your MacBook using a USB cable.
Step 2. Launch the QuickTime Player app on your Mac from the Launchpad.
Access QuickTime Player on the Mac
Step 3. When the app opens, click on the File menu at the top and select New Movie Recording. Although it says movie recording, it will let you mirror your screen.
Start New Recording in QuickTime Player
Step 4. Click on the red icon on the following screen and select your iPhone from the list. You will instantly see all the contents of your iPhone screen on your MacBook. That is how you mirror iPhone screen on Mac with ease.
Select iPhone as the Source Device in QuickTime Player
iPads give you a bit more space to view your content than iPhones and so you may want to do screen mirroring from your iPhone to your iPad. It only takes a few taps to do it. Here is how:
Step 1. Connect both your iPhone and your iPad to the same WiFi network if they are not already.
Step 2. Open Control Center on your iPhone by swiping up from the bottom of your screen. When it opens, tap on AirPlay.
Access the AirPlay feature on iPhone
Step 3. Choose your iPad from the devices list and it will connect. You are all done. Your iPhone screen should now be visible on your iPad.
Apple CarPlay is a smart driving companion that allows you to use your iPhone in a safer and more convenient way while driving. Although CarPlay does not offer true screen mirroring, it does provide seamless integration between your iPhone and your car’s infotainment system, mirroring iPhone music or video to your car’s built-in display.
To use Apple CarPlay, make sure that your car is compatible with the feature. Most vehicles manufactured after 2016 come with CarPlay support, but it’s always a good idea to check your car’s manual or the manufacturer’s website to confirm compatibility.
Step 1. On your iPhone, head into Settings and tap on Siri. Then, enable the option that says Allow “Hey Siri”.
Turn on Hey Siri on iPhone
Step 2. Head into Settings > General > CarPlay and you will get a prompt. Tap on Turn on Bluetooth if you would like to connect to your car via Bluetooth.
Enable CarPlay on iPhone
Step 3. Choose your car from the list and you will connect to it. That is all there is to it. Now that your iPhone is connected to your car via CarPlay, you can start mirroring your screen to your car display.
According to our survey to screen mirroring users, what they care about the most is the screen mirroring experience. There are about 42% of users select “stable connection” as the most important factor influencing their choice of screen mirroring software. Here are some suggestions for optimizing your screen mirroring experience:
There are various uses of screen mirroring on iPhone such as you can use it for presentations, tutorials, and so on. The feature works on most devices out there which is a really good thing. And in the cases where it does not work, you have a great alternative available to use.
