Is WiFi not working on phone but working on other devices? This article offers nine easy fixes to resolve the issue, from reconnecting the network to updating your phone’s system. Follow these steps to get your phone back online.
Is your WiFi not working on your phone but working on other devices? If yes, you’re not alone!
Undoubtedly, this common issue can be frustrating and disturb your daily routine. But worry not! We are here to help you to come out of this annoying situation.
Understanding the issue is the first step in fixing it. The problem could be due to multiple reasons, such as incorrect settings, software bugs, or simple oversights. This article will explore nine easy fixes to get your phone back online.
These solutions are simple yet practical. Let’s get started and solve the problem together!
There could be several reasons for WiFi not working on your phone but working on other devices. You need to find out which one of these is to blame in your case:
If this seems like a lot! Worry not! You’ll be happy with the easy fixes below.
There are different ways to fix the issue of WiFi not working on a phone but working on other devices. Below, we will discuss 09 easy fixes to resolve this issue. Let’s start with the basic solution.
The first method is reconnecting the WiFi after forgetting it. Just follow the steps mentioned below.
Step 1. Open the Settings application on your device.
Step 2. Next, go to the Network & Internet section.
Step 3. Then, click the Internet option to check the list of available WiFi networks.
Step 4. Now, click on the gear icon beside the connected network name.
Step 5. Click on Forget to let the device forget the password and other related information about the network.
Forget the Details for WiFi Network
Step 6. Finally, reenter the password to reconnect to the WiFi password.
That’s all about reconnecting WiFi after forgetting the password. Let’s move to the second potential fix to resolve the issue.
Are you an iPhone user and having the same issue on your phone?
Don’t worry anymore! You can quickly solve the problem of WiFi not working on a phone but working on other devices.
There are different ways to resolve the issue, but force restarting your iPhone is preferred.
The steps below will help you force restart your iPhone.
Restart Your iPhone
Hopefully, you now know how to force restart your iPhone. Now, let’s discuss the next easy fix to resolve the issue.
The WiFi connection impacts Airplane Mode. Whenever you turn on airplane mode, the WiFi turns off. Therefore, turning on and off the airplane mode might solve the issue.
Below are two methods for turning on and off the airplane mode: one for Android and the other for iPhone.
Follow the steps below to get on and off the airplane mode.
Turn Android Airplane Mode on and off
Checking the WiFi Router is another cause of WiFi not working on phones but working on other devices. Let’s suppose there is a little glitch with your WiFi router. You will have to reboot it.
Rebooting your WiFi will rewrite all settings and clear the cache. It helps your router get the correct IP address, and you will get the Internet back.
There are two ways to restart the router: The first one involves pressing the On/off button, and the second one is unplugging the power cable.
To apply way one, find your router and unplug the power cable. Plug it back in after 15 seconds (or 1 minute).
For some routers with an on/off button, press the router to shut down the device. Then, press again after 15 seconds.
Check your WiFi Router
You can use any of the above methods to check the WiFi router. Let’s move on to the next practical solution.
Are you still having the issue of WiFi not working on your phone but working on other devices? If yes, there might be bugs in your phone that you need to eliminate.
Thorny bugs can cause your phone to malfunction or lag. To fix the iOS system, you must use efficient third-party solutions like AnyFix. First, let’s see how to use this useful tool for iPhone.
Below are the steps to follow to fix the iOS system using AnyFix.
Step 1. First of all, download and install AnyFix on your computer.
Step 2. Launch the AnyFix on your computer and select System Repair Mode. Next, choose Repair Now.
Choose System Repair > Repair Now
Step 3 . AnyFix will start detecting your iPhone. Once your iPhone is detected, you will see the below interface. Here, choose Device Cannot Connect, then Start Now.
Choose Device Cannot Connect >Start Now
Step 4. Next, select a mode to repair your iOS device. Now choose the Standard Repair option (taking the Standard Repair as an example), then click the Standard Repair button.
Click Standard Repair Mode > Standard Repair Button
Step 5. You will see the interface below as you enter the standard repair mode. Now, check your device information and click “Download” to download the firmware for the iOS device.
Download your Device’s Firmware
Step 6. Once the firmware package download is completed, you will see the interface below. Click the “Start Standard Repair” button.
Hit Standard Repair Button
Step 7. Now, AnyFix will start repairing your iPhone. Do not disconnect your device until it restarts. Once the repair process is completed, you will see the below interface. Click “OK.”
Repair Completed Successfully
You’ve seen how simple it is to fix an iOS system using AnyFix. But what if you are not an iPhone user? Fret not! We have enlisted the solution for you, too.
DroidKit offers the best solution for fixing the Android OS. The tool safely fixes system issues for Samsung, Xiaomi, Redmi, and POCO devices. It also helps you recover lost photos, WhatsApp chats, messages, and more without rooting.
Let’s see how it helps you fix the Android OS issue! We will break down the complete process into simple steps.
Here are the steps to follow to fix the Android OS issues when the USB debugging option is enabled.
Step 1. The first step is to download and install DroidKit on your computer. Next, launch it on your computer and select System Fix mode.
Ensure the Android device has turned on the USB debugging option before.
Click System Fix Function
Step 2. Once DroidKit detects your Android device, Click on the Start button.
Hit Start to Initiate the Clean Process
Currently, this function supports Xiaomi, Samsung, Redmi, and POCO devices.
Step 3. The program starts downloading the firmware package. As the download process completes, click the Fix Now button.
Click Fix Now
Step 4. Now follow the onscreen instructions to put your device in download mode and click Next.
If your device fails to be detected, the software will ask you to disconnect and reconnect your device to the computer and put your device in the Download mode again.
Put your Device in Download Mode
Step 5. After downloading and verifying the firmware, DroidKit will automatically start repairing your Android system. You will see the interface below as the process completes, and your Android device will be restarted.
System Fixed Successfully
That’s all about using DroidKit to fix Android OS. It’s time to move ahead to the following practical fix.
You can effortlessly fix the issue of WiFi not working on a phone but working on other devices. To do this, you just need to reset your network settings. Here is how you can do it:
The below steps will assist you in resetting your network settings.
Step 1. First, launch the Settings application, scroll down, and choose System.
Step 2. Secondly, tap the Reset options on the following screen.
Step 3. Finally, select the Reset Wi-Fi, mobile & Bluetooth options to reset your network settings.
Check and Reset Network Connection
Now that we have discussed 06 easy fixes to resolve the issue. Let’s move to the next easy fix.
Another potential method is turning off WiFi networking services. To do this, open your phone’s networking services and follow the below steps.
Disable WiFi Networking Service
We have covered everything about disabling WiFi networking services. Now, let’s move ahead to the next practical method to resolve the issue of WiFi not working on phones but working on other devices.
Are you an iPhone user, and is there an iOS update pending in your system? If yes, update your iOS system firsthand.
One of the main causes of WiFi not working on your phone but working on other devices is your iOS system not being updated.
Once you update your iOS, it will solve all the bugs that may cause WiFi problems.
Update iOS System
4. Now, Tap on agree to accept the Terms and Conditions.
5. Finally, when the update is downloaded, tap on Install Now to install the update.
Let’s discuss the final solution to resolve the issue.
Sometimes, the best fix is to factory reset your iPhone. If you have tried each of the above solutions and they still don’t work, your best option is to factory reset your iPhone. Before you do that, recover your data first and then reset your phone.
The following steps will help you reset your iPhone effortlessly.
Step 1. First, go to settings and hit the Rest option.
Step 2. Secondly, click on the factory reset option and proceed.
Step 3. After completely resetting your iPhone, connect it to Wi-Fi and check whether it still works.
Reset All Settings on iPhone
So far, we have discussed all the 09 easy fixes. Next, let’s conclude our discussion.
WiFi is not working on phones but working on other devices can be annoying. These 9 easy fixes can help solve the issue, from forgetting the network to resetting your iPhone.
Consider using AnyFix for iPhone or DroidKit for Android for a more reliable solution.
These tools can quickly resolve WiFi connectivity problems and ensure your phone stays connected. Try these methods and enjoy uninterrupted internet on your phone again!
