7 Best iPhone Repair Software to Fix iOS System Issues
Want an iOS system repair tool but don’t know how to choose? Here we will 6 popular iPhone repair software to fix 150+ iOS system issues. Check them out and get your preferred one!
Author Avatar Joy Taylor Last Updated: Sep. 07, 2026
AnyFix – Best iOS Repair Software 2026
Download AnyFix to fix 150+ iPhone/iPad/Apple TV system issues within a few clicks. No technical skills required. Standard Repair is designed for common issues without erasing device data; Advanced and Ultimate Repair erase data. Check current device and iOS compatibility before repair.
While iPhone is renowned for its performance and reliability, it is not immune to occasional technical issues. Users may still encounter problems such as iPhone keeps restarting, system crashes, unresponsive screens, or update failures that disrupt their experience. If basic troubleshooting does not work, software to fix iPhone system problems can provide a guided repair workflow before you consider a full restore or hardware service.
Quick answer: The best iPhone repair software depends on the problem and how much data risk you can accept. For common software issues, start with a standard/no-data-loss repair mode when available. For severe failures, deeper repair modes may erase the device. If the problem is caused by damaged hardware, battery failure, liquid damage, or a broken display, iOS repair software is not the right fix.
Common iOS System Issues in Daily Life
Despite Apple’s continuous improvements to iOS, system glitches are also inevitable, which can affect functionality and user experience. Here are some of the most common iOS system issues users face:
  • iPhone Stuck on Apple Logo: This issue is usually triggered by failed system updates, interrupted data transfers, or incomplete restores. Jailbreaking attempts can also cause this issue. Force restarting the device or using iTunes/Finder to restore it in recovery mode may help.
  • iPhone Boot Loop: A boot loop is often caused by corrupted system files, a failed iOS update, or hardware-related issues like battery faults. Sometimes, faulty apps or low device storage can also trigger it. You can try resolving this by updating the iOS via recovery mode.
  • iPhone Frozen: This problem may result from overloaded system resources, app crashes, or bugs introduced in recent software updates. Limited storage or older hardware in devices are especially prone to this. A force restart might restore functionality. If freezing persists, uninstalling problematic apps or running a system repair with dedicated software might be necessary.
  • iPhone Black/White Screen of Death: This issue is often caused by a critical system crash, firmware corruption, or hardware failure. Jailbreaking or incompatible apps may also be the reason. Basic solutions include checking if the device needs charging, trying a hard reset, or using system repair software. If those don’t work, professional hardware inspection may be required.
While basic troubleshooting methods may resolve some above iOS issues, they are not always effective, especially with more complex or persistent problems. Therefore, professional iPhone repair software offers a reliable and efficient solution, allowing you to fix system errors quickly, without requiring technical skills.
How to Choose the Best iPhone Repair Software?
To choose software to fix iPhone system problems, compare more than the number of issues a vendor claims to support. The most useful differences are repair depth, data-loss risk, current device/iOS compatibility, free-function limits, recovery-mode support, and whether the tool is designed for software rather than hardware faults.
How We Compared These iPhone Repair Tools
For this update, we compared the seven tools using their current product pages and repair guides, focusing on the factors that affect a real repair decision rather than relying on a single advertised success-rate number.
  • Repair coverage: common stuck screens, boot loops, update/restore failures, recovery mode, and related iOS system faults.
  • Data impact: whether the standard repair path keeps data and whether deeper modes erase the device.
  • Repair modes: whether users can choose between standard and deeper repair workflows.
  • Free-use boundary: whether the trial/free version can actually repair the system or only test compatibility/use selected utilities.
  • Compatibility: whether the vendor maintains support information for current iPhone/iOS generations.
  • Ease of use: guided firmware download, device detection, and recovery/DFU instructions.
Important: Software repair cannot fix physical damage. If an iPhone has liquid damage, a failed battery, damaged charging hardware, or a physically broken display, use Apple or a qualified hardware repair provider instead.
Quick Comparison: 7 iPhone Repair Software Options
Tool Best For Data-Preserving Repair Deeper Repair Free-Use Note
AnyFix Overall guided iOS repair Standard Repair Advanced/Ultimate erase data Some utilities are free; full System Repair requires activation
PhoneRescue for iOS Users who also need data-recovery features Standard Mode Advanced Mode erases data System Repair is not available in the free version
Dr.Fone System Repair Broad toolkit users Standard Mode Advanced Mode erases data Trial limitations apply
iMyFone Fixppo Standard vs. advanced repair choice Standard Mode Advanced Mode erases data Recovery-mode utility has free use; full repair requires paid access
Joyoshare UltFix Simple guided iOS repair Check current Standard Repair terms Check current Advanced/Deep terms Trial limitations apply
TunesKit iOS System Recovery Repair plus backup/restore utilities Standard Repair Deep Repair erases data Includes selected free utilities; repair activation may be required
UltFone iOS System Repair Repair plus recovery-mode tools Standard Repair Deep Repair erases data Repair can be tested; full repair requires upgrade
Selection rule: If keeping data is your priority, begin with a standard repair mode and back up first whenever the iPhone is still accessible. If Standard Repair fails, read the deeper-mode warning before continuing because Advanced, Deep, or Ultimate modes may erase all device data.
1. AnyFix – Fix iPhone Software Problems [Easy & Secure]
AnyFix is a powerful iOS system repair tool that offers solutions for more than 150 iOS/iPadOS/tvOS problems. This includes iPhone problems such as iPhone won’t turn on, iPhone is frozen, iPhone is disabled connect to iTunes, iPhone stuck on iOS 18 update requested, iOS 18 update failed error, etc. It is an iOS system repair tool that gives you a one-stop solution to quickly fix various iPhone issues and brings your Apple devices back to normal in easy steps.
Main Features:
  • Covers 150+ system problems, including both common and uncommon ones.
  • Provides 3 repair modes to guarantee a high success rate: Standard Repair, Advanced Repair, and Ultimate Repair.
  • Works for almost all models of iPhone, like the latest iPhone 16 and iOS 18.
  • Standard Repair is designed for common system issues without erasing device data; Advanced Repair and Ultimate Repair erase device data.
  • Allows to fix iTunes issues, 1-click reset devices, upgrade iOS, enter recovery mode, etc.
Pricing: $35.99 for 3-month plan, $39.99 for 1-year plan. Get AnyFix with a big save today!
How to repair the iPhone system with AnyFix in easy steps:
Step 1. Download and install AnyFix on your computer and click System Repair. Here you can see the problems that AnyFix supports solving.
AnyFix Main Screen
AnyFix Main Screen
Step 2. Choose the category that most suits your needs and click Start Now. Let’s take Screen Stuck as an example.
Step 3. Then you can choose from the 3 modes to fix your iPhone system problem. The standard mode will not cause data loss, while the other 2 modes will erase data on your iPhone. You can decide to choose one according to your system status.
AnyFix Standard Repair
Step 4. Then you can just follow the instructions to finish the system repair with AnyFix.
2. PhoneRescue for iOS – iPhone Data Recovery & iOS Repair Tool
Another effective iPhone repair software in the market is PhoneRescue for iOS, which is capable of helping you fix a wide range of iPhone issues like iOS upgrade failure, iPhone stuck in white Apple logo, iPhone unable to start iOS, and so on. Except for iOS repair, PhoneRescue for iOS is a complete iPhone solution for iOS data recovery and iOS lock screen removal. Thus, even if data loss happens while repairing iPhone, you can get iPhone data back with PhoneRescue for iOS easily. For more outstanding advantages of PhoneRescue for iOS, you can refer to the following tips.
Main Features:
  • Fixes a wide range of iPhone, iPad, or iPod touch issues from any type of breakdown.
  • Provides Standard Mode and Advanced Mode to choose one for your needs.
  • Works for almost all models of iPhone, including the latest iPhone 16, and supports iOS 18.
  • Standard Mode is designed to resolve common system issues while keeping original data; Advanced Mode is intended for more complex issues and erases device data.
Pricing: $49.99 for 1-year plan, and save up to 30% for PhoneRescue NOW!
Click Device Rescuer and Choose Repair iOS System
Repair iOS System via PhoneRescue for iOS
3. WonderShare Dr.Fone
Wondershare’s Dr. Fone is another iOS repair software we are going to introduce to you. This iOS toolkit is most often used to fix the iPhone won’t turn on issue. Besides, it also excels in handling other iPhone issues like iPhone stuck in recovery mode and in a boot loop. It is very easy to use; you just need to get your iPhone connected to the computer and launch the Dr.Fone software, then you can restore your iPhone to normal by following the instructions.
Advantages:
  • Data impact depends on repair mode: its current Standard Mode is designed to repair common iOS problems without data loss, while Advanced Mode resets the device and erases data.
  • Fix various iOS problems: stuck on the white Apple logo, black screen of death, stuck in a boot loop, stuck on connecting to iTunes, iPhone frozen, iPhone is disabled connect to iTunes and stuck in recovery mode, and so on.
  • Fix iTunes errors: It can help you fix various iTunes errors like iTunes error 4013, error 27, error 9, and so on.
  • Wide compatibility: It works for almost all models of iPhone, iPad, and iPod touch. iOS 15 is supported.
  • Downgrade iOS: It also gives you more solutions, like downgrading the iOS version.
Disadvantages:
  • The functionality of the free version is limited. If you want to experience more functions, you need to pay for them.
  • Sometimes, it cannot recognize your iPhone.
  • A jailbroken iPhone will be updated to the non-jailbroken version.
Pricing: $59.95 is needed to use Dr.Fone – System Repair (iOS)
Wondershare iPhone Repair
While repairing your iPhone with Dr.Fone, your device will be updated to the latest version. If you want to downgrade it to the previous iOS version, just read How to Downgrade iOS with/without iTunes.
4. iMyFone – Fixppo
iMyFone’s Fixppo is the next iPhone repair software that will be introduced. It is designed to fix various iOS issues: iPhone stuck on the white screen, Apple Logo, Recovery/DFU Mode, restarting loops, getting bricked with a frozen screen, or simply won’t start. It also comes with 3 modes, each designed to help you repair your device to normal. If you want to know more about it, just read the following text to get its advantages and disadvantages.
Advantages:
  • Fix iPhone software problems: Almost all iPhone problems are covered by Fixppo, like white/black screen of death, iPhone frozen/boot loop, iPhone update/restore failure, iPhone stuck in recovery mode/spinning circle, won’t turn on, etc.
  • Without data loss: You are offered 2 modes: Standard Mode and Advanced Mode. The former one is mainly designed to fix problems like “iPhone stuck on frozen”. And the latter enables a disabled device, and repairs the iPhone problems that the Standard Model cannot fix.
  • Downgrade iOS: iMyFone’s Fixppo enables you to downgrade your iPhone to the previous version without jailbreak.
  • Enter/Exit recovery mode with ease: You can enter/exit recovery mode with one click.
  • Fix iTunes errors: It can help you fix various iTunes errors, like error 2.
Disadvantages:
  • The Advanced Mode will cause data loss.
  • It can not be used to unlock a locked iPhone.
  • Many functions cost.
Pricing: $29.95 for 1-month plan, $39.95 for 1-year plan.
iMyFone Fixppo iPhone Repair
5. Joyoshare UltFix
Joyoshare UltFix is an iOS System repair tool, designed with dual repair modes. You can choose Standard Mode or Advanced Mode as needed. It can repair 150+ possible iOS issues, such as iPhone stuck on the black screen, the white Apple logo, iPhone keeps restarting, etc. It is easy for you to independently complete the whole system repair process in 3 steps.
Advantages:
  • Fix various iOS problems: Repair more than 150 kinds of iOS/iPadOS/tvOS issues.
  • Without data loss: Recover iOS System without Causing Data Loss.
  • Wide compatibility: Work for almost all models of iPhone. The latest iOS 16 is supported.
Disadvantages:
  • The trial version has limited features.
Pricing: $49.95 for Family License.
Joyoshare UltFix iPhone Repair
6. Tuneskit iOS System Recovery
Tuneskit iOS System Recovery is another iPhone repair software worth introducing. It can help you recover your iOS/tvOS to normal with no data loss. No matter whether your iOS device is stuck in recovery mode/DFU mode/white Apple logo, or black screen, it will get you out of the trouble and recover your device back to normal quickly.
Advantages:
  • Fix iOS/tvOS with 2 Modes: Provide 2 different modes, including Standard Mode and Advanced Mode for you to fix most common iOS or tvOS errors.
  • Without data loss: Recover iOS System in standard mode without Causing Data Loss.
  • Wide compatibility: Support both Windows and Mac. It works for almost all models of iPhone. The latest iOS 16 is supported.
Disadvantages:
  • The current product includes selected free utilities, while full system-repair functionality may require activation; check the current license page before purchase.
Pricing: $29.95 for 1-month plan, $39.95 for 1-year plan, $49.95 for lifetime license.
Tuneskit iPhone Repair
7. UltFone iOS System Repair
​UltFone iOS System Repair is a professional-grade tool. It can repair a wide range of iOS issues, including devices stuck on the Apple logo, recovery mode loops, black or white screens, and boot loops. This tool offers two different repair modes, standard and deep mode, supporting fixing common problems without data loss or performing a complete system reset.​
Advantages:
  • 2 different recovery modes: Two recovery modes are provided: Standard or Deep Repair Modes, enabling users to choose the appropriate solution based on issue severity.​
  • Downgrade iOS without iTunes: Restore to a previous iOS version without jailbreaking or data loss.​
  • Factory reset without passcode: Reset your device even if you’ve forgotten your passcode.​
  • The current UltFone product page lists support for recent iPhone and iOS/iPadOS generations; verify the exact device and OS version before repair.​
Disadvantages:
  • The free version has limited features; full functionality requires a paid license.​
  • Using the deep repair mode will erase all data on the device.
Pricing: $24.95 for 1-month plan, $49.95 for 1-year plan, $79.95 for lifetime license.
FAQs about iOS System Repair Tool
1. Does iPhone repair software really work?
Absolutely, the answer is YES. As we introduced several top iOS system repair tools above. All of them are able to repair iPhone software to put your iPhone into normal. Although they are different in cost, functions, repair speed, how many problems they can fix, etc., you can check the details above and choose the best suitable one for your iPhone.
2. What is the Apple Self Repair Program?
Apple provides an official self-repair program, that is Self Service Repair, to individual users, particularly those with technical experience. Self Service Repair provides users with access to genuine Apple parts, tools, and repair manuals to perform their own out-of-warranty repair.
3. Does Apple fix software issues for free?
Whether it is free or not depends on the situation. Apple may fix software issues for free if your device is under warranty, covered by AppleCare+, or affected by a known iOS/macOS bug. However, if your device is out of warranty or the issue results from third-party interference, service fees may apply.
4. Is there free software to fix iPhone system problems?
Some tools offer free utilities such as entering or exiting Recovery Mode, device detection, or compatibility checks, but full iOS system repair commonly requires a paid license. Check what the free version can actually complete before downloading or purchasing.
5. Will iPhone repair software erase my data?
It depends on the repair mode. Standard repair modes from several tools are designed to preserve data for common system problems, while Advanced, Deep, or Ultimate modes typically erase the device. Back up first whenever possible and read the mode description before starting.
6. Can iPhone repair software fix hardware problems?
No. These tools are intended for iOS software and firmware problems. Physical screen damage, liquid damage, battery failure, damaged ports, and other component faults require hardware diagnosis or repair.
If you need software to fix iPhone system problems, choose based on the issue, repair mode, data-loss risk, compatibility, and free-use limits—not only the number of problems advertised. AnyFix is a strong all-around option for guided iOS repair because it separates Standard, Advanced, and Ultimate repair paths and clearly identifies which modes erase data. If keeping your files is the priority, back up first whenever possible and begin with Standard Repair. For physical damage or a device that remains undetected after software troubleshooting, move to hardware service instead of repeatedly running repair software.
