Checkout the common iOS 16 Beta and iOS 16 Update problems you may meet, and follow the quick fixes to get your iPhone back to normal.
With AnyFix – iOS System Recovery you can get your iPhone back to normal from iOS update issues like iPhone stuck on Apple Logo, iPhone won’t turn on, etc. It also helps quickly upgrade and downgrade your iOS in clicks.
iOS 16 has been released this year, and now you can download the iOS 16 version to have a try on your iPhone. Although we all know that every newer iOS version will not only bring fresh features to make our life more fun but also update fixes for bugs occurring in the previous versions. However, this does not mean iOS 16 is perfect and bugless. According to our data collection from many mainstream and non-mainstream forums, and our user’s emails and feedback, many problems and issues occur during iOS 16 updating, and use afterward such as iPhone stuck on preparing update. Also, when you update to the public iOS 16 version, you may also meet some iOS update problems, so to help all users solve these annoying troubles, we list them one by one, with quick and practical solutions, in the following.
If you can’t wait for the official release of iOS 16, the iOS 16 public beta is now available. But you should know, it is unstable and not perfect. Here are some iOS 15 Beta bugs Apple reported.
“Software Update Failed. An error occurred downloading iOS 16, or “Software Update Failed. An error occurred installing iOS 15”.
Tip 1. Check if your devices support iOS 15 because Apple would leave some old devices behind when the newest iOS generation coming. iOS 15 supports iPhone 6s and later. For example, you can’t upgrade iPhone 5 to iOS 15. To make sure whether your iPhone iPad iPod is on the list or not, please visit here
Tip 2. Reset Network Settings. Go to Settings > General > Reset > Tap on Reset Network Settings.
Tip 3. Force a Restart on Your Device. Press and hold both the power button and the Home buttons and continue holding until the Apple logo appears.
Tip 4. Turn Off Wi-Fi and Switch to the Cellular Data.
Tip 5. Apply iTunes to update iOS 15 on the computer.
After downloading iOS 15 updating files, there will be a verifying update step. But sometimes iDevices would be stuck on this verifying update screen, or even notice unable to verify update.
iOS Update Problems – Verifying Update Issue
Method 1. Make sure your network be connected all the time.
Method 2. Hard reset or reboot your iPhone.
Method 3. Update iOS 15 with iTunes on the computer.
View the details of each step to fix verifying update issue, please refer to this guide: How to Fix iPhone Stuck on Verifying Update >
This iOS 15 issue happens more commonly on those devices with 32G or 64G storage. The most direct solution is to transfer our data and files from iPhone iPad iPod to another iOS device.
iOS Update Problem – Insufficient Space For Download
Normally we can use iTunes to back up our devices. But we also know iTunes aims at backing up all data. So if the number of your photos, videos, music, or others, is extremely large, it would be costing much time. So we recommend an iTunes alternative – AnyTrans to selectively transfer data and make room for iOS 15 updating.
Surely, you can also refer to this tutorial to clean up space: How to Clean up iPhone iPad iPod for iOS updating >
Almost every time new iOS updating, users would complain about the newest iOS consumes power largely and fast. iOS 15 may not an exception, either.
iOS Update Problem – Battery Fast Draining
Tip 1. Restart Your Device. Hold down the power button, slide it to turn it off. Power it back on.
Tip 2. Disable Widgets. Swipe to the right while you’re on your device’s home screen. Scroll all the way to the bottom of your widgets and select Edit. To deactivate a widget, tap the red circle with the white line and tap Remove.
Tip 3. Use Low Power Mode. To enable Low Power Mode on your device head into Settings > Battery > Low Power Mode > and toggle it On whenever you need it.
Tip 4. Disable Raise to Wake. To shut off Raise to Wake, go into the Settings app > Display & Brightness and toggle the Raise to Wake function off.
Tip 5. Turn off Background App Refresh. Go to Settings > General > Background App Refresh > Turn it off then.
Tip 6. Reset All Settings. Go to Settings > General > Reset > Reset All Settings > Enter your passcode.
After upgrading to iOS 15, your iPhone may be encountered not recognizing USB, and charging slowly, or even not charging at all.
Solution 1. Use an Apple-matched USB cable, and don’t use any cheap low-quality cables.
Solution 2. Check and make sure your USB cable is not damaged.
Solution 3. Try hard resetting your iPhone or iPad.
Solution 4. Change a USB cable if you have one.
Solution 5. Use an iPad Charger will make it faster to charge iPhone.
View these solutions in detail, please check the full guide: How to Fix: iPhone iPad Not Charging or Charging Slowly >
Some users reported that their iPhone iPad iPod was faced with a temperature too high warning – “iPhone iPad iPod needs to cool down before you can use it.” during updating.
iOS Update Problem – Overheating Issue
Solution 1. The easiest way is to wait for a while until the device cools down itself. Also, you can choose to reset it or turn it off and try downloading the update again.
Solution 2. Take off the device case. Obvious enough, but this will help indeed.
Solution 3. Turn off Location Services. GPS is one item that heats up the iPhone iPad iPod the most. Turn it off using Settings > Privacy > Location Services > Off.
You can also follow this guide: Why Does My iPhone Get Hot and How to Fix It to get more.
If you find your cellular data is strangely slow, or even not working on iPhone, after updating to iOS 15, you can try the following means.
iOS Update Issue – Cellular Problem
Step 1. Check with your carrier to determine if there is an outage in your area.
Step 2. Restart your device. Hold down the power button, swipe to turn it off, hold the button down again to power back on.
Step 3. Check for a carrier update. Go to Settings > About, if you’re still experiencing this problem.
Step 4. Turn cellular data off, after a few seconds, toggle it on.
Step 5. Enable Airplane mode. Go to Control Center > Turn on Airplane Mode > Turn it off in about 30 seconds.
Step 6. Reset Network Settings. Head into Settings > General > Reset > Reset Network Settings.
iOS 15 updating sometimes also leads to the abnormal state of Wi-Fi, such as iPhone iPad iPod cannot connect to Wi-Fi, Wi-Fi keeps dropping, Wi-Fi becomes grey, Wi-Fi automatically turns on, or won’t turn on, Wi-Fi is very slow, etc. However, here are several quick tips to fix them.
iOS Update Issues – Wi-Fi Problems
Solution 1. Make sure it’s not a router/Internet Service Provider (ISP) problem. You can try unplugging your router for like 5 minutes, and then restart it and test again.
Solution 2. Reconnect the Wi-Fi. If you’re pretty sure it’s not a router issue, you’ll go to Settings > Wi-Fi > Select your connection > and Tap Forget this Network at the top of the screen > Reconnect if you can and check for problems.
Solution 3. Reset Network Settings. Head into Settings > General > Reset > Reset Network Settings.
Just like Wi-Fi problems, iOS 15 updating may also put in such situations, Bluetooth won’t connect to iPhone/Car, Bluetooth connection drops frequently, Bluetooth always on, or Bluetooth won’t turn on iPhone or iPad, etc. Even the latest iPhone has the same Bluetooth issues. Possible solutions:
1. Reconnect Bluetooth. Settings > Bluetooth > Tap on the blue “i” in the circle next to the Bluetooth connection giving you problems > Tap Forget This Device > Try reconnecting.
2. Reset Network Settings. If the 1st quick fix doesn’t work well, try resetting your device’s network settings. Settings > General > Reset > Reset Network Settings. This process will take a few seconds to complete and your device will forget known Bluetooth devices.
3. Reset All Settings. Settings > General > Reset > Reset All Settings. Please note that this will revert your settings to factory defaults.
4. If you’re dealing with iOS 15 Bluetooth problems in a car, try these fixes but you also might need to consult your car’s manual and/or your car’s dealer for a potential fix.
Read this guide to get more solutions to fix iOS Bluetooth Issues >
Occasionally, on iOS 15, the lock screen shows not the set lock screen wallpaper, but the home screen wallpaper. To fix this problem is pretty easy. You just need to restart your iPhone iPad, the lock screen wallpaper would return to normal.
You can also visit this page for more info: How to Fix: iPhone Live Wallpaper Not Working >
Like wallpaper, there is also another tiny iOS 15 problem – AirPods, or headphone problems. Sometimes, AirPods cannot connect to iPhone iPad iPod. To fix it, take both AirPods off > Put them both inside the case > Close the case, and wait for 5-10 seconds > Take them out with the case next to the phone.
iOS Update Problems – AirPods issue
Or, you can visit this guide of ours, finding more solutions to AirPods not connecting to iPhone iPad: How to Fix AirPods Won’t Connect to iPhone/iPad >
After talking about AirPods, sound problems must be the next one of iOS 15 issues. If your device sound suddenly cuts out while you’re on the home screen or while you’re using an application, don’t panic. You should be able to fix the issue in seconds.
1. Restart iPhone iPad iPod. Hold down the power button, slide it to turn off, power the device back on, and check.
2. Toggle Bluetooth off and on to see if it fixes your issue.
3. If these sound problems happen to a specific app, make sure it is the latest version.
4. Take notice of your speaker grille to make sure debris isn’t causing the issue. If you notice something, carefully remove it to see if that improves your device’s sound.
The other iOS 15 sound-related problem is about the iPhone ringtone. Many users have emailed us asking for help with ringtone not working on iPhone, so we gather a few possible solutions:
Method 1. Go to Settings > Sounds to adjust the volume of the ringtone.
Method 2. Make sure you have the “mute” button set to ring instead of silent.
Method 3. Restart your iPhone.
Method 4. Contact Apple.
For the details of each method, please follow this guide: How to Fix iPhone Ringtone Not Working >
On iOS 15, iPhone iPad iPod touchscreen maybe becomes laggy, or slow to respond, or even turn unresponsive, for some users. You can take the following tips to get them solved.
Solution 1. Clean Your Screen. Have a check on your screen to see if there are some oily or liquid splits and clean the screen with a soft cloth. If you have a screen protector, you can remove it to have a try.
Solution 2. Restart Your iDevice. Press and hold down the on/off button and drag the slide to power off, and then turn on your iPhone/iPad/iPod touch after a few seconds.
Solution 3. Reset Your iDevice. Hold down the power button and home button (volume down and power button on an iPhone 7/iPhone 7 Plus) at the same time. Your phone will reboot in a few seconds and the touchscreen problems should be gone. If it doesn’t work the first time, try it again until it works. In the past, it’s taken as many as three hard resets.
Solution 4. Restore Your iDevice. Restore your device via iTunes. Make sure to download and install the latest version of iTunes.
Sometimes, when we use touch ID to unlock your iPhoneunlock your iPhone or pay a bill at App Store or some other shopping websites, it will be unresponsive, or not working. To solve it, go to Settings on > Tap on Touch ID & Passcode > Enter your Passcode or Password > Turn off iTunes & App Store > Press the Home button and reboot your iPhone or iPad > Then go to Settings and turn on iTunes & App Store in Touch ID & Passcode.
iOS Update Problems – Touch ID Not Working
For more useful solutions, please read How to Fix iPhone Touch ID Not Working >
iOS 15 updating sometimes will also lead to some apps breaking down, and iMessage is one of them. Under this iMessage, not working problem, iMessage cannot be delivered, iMessage stuck on activating screen, an error occurred during iMessage activation, message app keeps crashing, or iPhone/iPad not receiving or sending messages. But there are plenty of methods to fix them.
iOS Update Problems – iMessage Not Working
1. Check if Apple’s iMessage server is down.
2. Make sure you’ve got a network connection. If your cellular data or Wi-Fi is not working, you can jump to part 7 and part 8 looking for solutions.
3. Make sure Messages are set up correctly. Check you’re set to send and receive iMessages by going to Settings > Messages and checking that iMessage is turned on. Also, check that your phone is set up correctly to receive iMessages: go to Settings > Messages again and check the addresses and mobile numbers you have listed in Send & Receive.
4. Turn iMessage off and on again and restart Messages.
5. Delete some messages. If there are too many videos and photos, they will also cause iMessage to slow down.
To get more info on iMessage/message issues in iOS 15, refer to this quick guide >
Many users also complain that iPhone iPad cannot connect to App Store, App Store not working, or is down, after updating to iOS 15. How to fix it?
iOS Update Problems – Cannot Connect to App Store
1. Turn On Cellular/Mobile Data for App Store. Many times we have disallowed App Store to use cellular data. Go to Settings > iTunes Store&App Store > Enable Cellular data
2. Sign Out from iTunes and Sign In again.
3. Set Date & Time automatically. Settings > General > Data&Time > Toggle on Set Automatically.
Read more tips to Fix App Store Not Working on iPhone iPad iPod >
Besides App Store is down, we often face with troubles of apps not downloading and updating. To fix them, restart your device and try the download again. It should work. If your download or upgrade is still stuck, rapidly tap Update on an app before the Open symbol appears.
iOS Update Problems – Unable to Download App
Every time iOS updating, there are some users reporting that their photos, music, video, contacts, etc. are disappearing. So every time iOS updating we would always notice our users back up their devices before upgrading, with iTunes, iCloud, or some iTunes alternative application. As if data gets lost, you can directly recover them from the backups. However if unfortunately, you have not backed up your devices, there is no need to worry about it, because we can also get back disappeared data with a mobile data recovery software – PhoneRescue for iOS.
Recover from iOS without Backup
For detailed information, please refer to how to recover lost data due to upgrading >
Siri is blending in our daily lives. We can just say “Hi, Siri” to find what we would like to eat, where we want to go and how, and more. However, there is a possibility that Siri may do not work after iOS 15 upgrading. How to fix this?
iOS Update Problems – Siri not Available
Solution 1. Make sure network connecting is good, cellular or Wi-Fi.
Solution 2. Go to Settings > Siri and make sure the “Hey Siri” feature is on.
Solution 3. Try resetting your settings by going to Settings > General > Reset > Reset All Settings. Then, set up Siri once again.
Solution 4. If you have Bluetooth on, try turning it off and then trying Siri again.
To get more suggestions on solving Siri problems, please refer to this guide >
Among many iOS users, Safari may be their favorite web browser, including me personally. However Safari would occasionally break down after iOS 15 updating, feedback from many users, with symptoms of Safari not working frequently, crashing all of sudden, page loading slowly, page interface is broken, etc.
Step 1. Check network connection.
Step 2. Restart Safari, or the device.
Step 3. Reset network settings.
Step 4. Clean Safari junk files. Usually, we recommend sincerely our users to try with PhoneClean to clean browsing junk files, cookies, temporary files, downloading files, etc. Besides, it also works for Chrome, Firefox, Opera.
If you want to get more detailed information, refer to our tutorial: How to Fix iPhone iPad Safari Not Working >
There’s very little chance that you encounter this error on your iPhone when you try to activate but still when you do, things can be a little bad. However, it can still be solved.
iOS Update Issues – iPhone iPad Activation Failed
1. Restarting your iPhone is going to be one of the simplest ways to try and fix the error.
2. Check to see if the problem is with the SIM-card / carrier. If you are trying to activate a different carrier on a locked iPhone (which hasn’t been unlocked yet), you’ll get the activation errors obviously.
3. Check Wi-Fi/Network.
4. Restore device with iTunes.
If you want to learn more details, you can check: How to Fix Can’t Activate iPhone iPad iPod touch >
After upgrading to iOS 15, your iPhone may randomly restart. How to fix this?
iOS Update Issues – iPhone Reboot Loop
1. Check whether the lighting ports of your device are clean.
2. Change another cable, charger and even battery to get your device to work in normal.
3. Restart or Force Restart Your Device. Press and hold both of the “Sleep” and “Home” buttons at the same time for 10 seconds until the Apple logo appears on the screen.
4. Reset All Settings. Go to Settings > General > Reset > Reset All Settings. This method will not remove any data on your device. It just reset all settings to factory default.
Besides the above methods, there are some other simple tips you can have a try, read this tutorial: How to Fix iPhone iPad Keeps Restarting >
When we upgrade to iOS 15 with iTunes, there occasionally occur some error messages, such as iTunes error 9/14/54…To fix these iTunes unknown errors, you can try these tips:
iOS Update Issues – Various iTunes Errors
1. Check USB cable.
2. Update iTunes to the latest version.
We also write many topic pages about these iTunes errors, you can directly visit them to look for more possible solutions:
How to Fix iTunes Error 9 via 5 Efficient Ways >
How to Fix iTunes Sync Error -54 >
If iPhone iPad cannot turn on after iOS 15 upgrading, you can fix it with:
iOS Update Issues – iPhone Won’t Turn On
1. Connect iPhone iPad to the power source
2. Try a hard reset
3. Restore iDevice with iTunes
4. Force device to Recovery Mode
5. Put iPhone iPad into DFU Mode
6. Fix iPhone iPad won’t turn on with third-party software
Get a more detailed tutorial, please visit: How to Fix iPhone iPad Won’t Turn On >
This is a small problem. Normally notifications appear on the lock screen. But after iOS 15 upgrading, they don’t appear as they should, but they’re chopped up and separated between the top, bottom, and middle of the device screen.
Solution 1. Restart your iOS device. Press the Sleep/Wake and Home buttons (Volume Down buttons for iPhone 7/7Plus) for at least ten seconds, until the Apple logo shows up.
Solution 2. Clear all on-screen notifications by tapping (or force pressing) the “x” on the notification screen. Wait to receive a new notification and see if the problem has been fixed.
You can also have a look at this post to find more solutions: How to Fix Notification Not Working on iPhone iPad >
This problem has been existing on the previous iOS update, it seems still not being solved on iOS 15, either. It frequently occurs when you upgrading iOS 15 directly on the device. So the most frequently used method is to restore your device and upgrade, with iTunes.
Step 1. Update your iTunes to the latest version. Connect your iPhone and run iTunes.
Step 2. Click the device button.
Step 3. Select Restore Backup… and choose a recent backup file. Then click Restore. (Notice that if your iPhone backup was encrypted, iTunes will ask you to enter the password to unlock your iPhone backup.)
If these 3 steps are too much simplified, and to get more details, please refer to this guide >
In the 16th part, we have already talked about messages, not working issues. Just like it, Calls sometimes may have something wrong. You can’t make calls and receive them. How to fix this?
Tip 1. Reset Network Settings.
Tip 2. Update your carrier.
Tip 3. Verify blocked phone numbers.
Tip 4. Try re-inserting the SIM card.
Tip 5. Try to restore your phone and set it up as new.
For more information, please read on this guide >
When restoring and updating devices with iTunes, there could occur one message iPhone/iPad software update server could not be contacted. To fix it, you can try the following tips:
iPhone Software Update Server Could Not Be Contacted
Tip 1. Check your network settings and try again later.
Tip 2. Try to update via OTA.
Tip 3. Download the firmware manually for the update.
For a detailed description of each tip, please refer to this guide: How to Fix iPhone/iPad Software Update Server Could Not Be Contacted >
The problems in this part probably are the most head-scratching ones, for most iOS 15 users. During or after updating, iPhone iPad suddenly stuck in recovery mode, on Apple logo, or even become a brick.
To get rid of such problems, you need firstly back up your device, and then try the following tips.
Tip 1. Force Restart your device by holding both Power and Home buttons.
Tip 2. Restore your device with iTunes. You can connect your device to iTunes on your computer and recover in Recovery Mode.
Tip 3. Use an iOS repairing software – PhoneRescue for iOS to fix this issue.
For more details, read How to Fix iPhone iPad Stuck in Recovery Mode >
iOS 15 will be released this September and you can upgrade your iPhone via Air or iTunes. However, some users may find that there is no iOS 15 update notification at all in the Settings or popping up a message “Unable to Check for Update. An error occurred while checking for a software update”, when heading to upgrading over the Air. Firstly iOS update not appearing in settings is kind of very common issue for every iOS generation upgrading, not just iOS 15. Secondly, you can try these steps below to fix this iPhone problem quickly;
Step 1. Make sure your iDevice connecting to the power charger and Wi-Fi. This is because, under low power and cellular data, Apple will not allow iOS updating. Then check if iOS 15 showing up.
Step 2. If you have downloaded the iOS 15 beta version on your device, iOS 15 will not appear in the settings, either. So you need to delete the beta profile firstly, and then get started with the regular version updating. To delete the beta profile, go to Settings > General > Scroll down to Profiles & Device Management > Click on the beat version and delete this profile.
Step 3. If this iOS 15 bug is still there, you can try a force restart your iDevice: Press and hold down the On/Off button > While continuing to hold the On/Off button, press and hold the Home button > Keep holding them until the screen turns back on and shows the Apple logo. Then go to Settings > General > Software Update to check if iOS 15 shows up.
Step 4. The last choice is updating iOS 15 with iTunes instead of Air if all steps above do not work for you.
Surely, for more detailed methods of this iOS 15 bugs, we also write about an article for you, check it now: How to Fix iOS Update Not Showing Up >
As a music lover, the Apple Music app would be the most indispensable tool on iPhone iPad; And you would never allow Apple Music not working on iPhone iPad when you enjoy the songs. So in this part of iOS 15 bugs, we mainly show you how to fix various iOS 15 Apple Music problems.
Normally here are common iOS 15 Apple Music problems we may encounter;
Apple Music Problem -Unable to Play Music
Unable to purchase
If you are suffering from such iOS 15 Apple Music bugs above, or others related, you can try the following quick solutions:
Tip 1. Go to Settings to turn on the Airplane Mode. Wait a few seconds and turn back off again. If this does not work, do this after a reboot.
Tip 2. Restart your device and the Music app, then swipe up on the Music app to close it. Finally, relaunch the Music app.
Tip 3. Go to Settings > General > Reset > Reset Network Settings to reset your network settings.
Tip 4. Go to the App Store app, then check out the Updates to update at least one app.
Tip 5. Update the iTunes to the latest version.
Tip 6. Force restart your device by pressing and holding the Sleep/Wake (On/Off) and Home buttons together until you see the Apple logo.
Certainly, you can also directly head to the topic page for more detailed solutions to this iOS 15 bug: How to Fix Apple Music Not Working >
After updating to iOS 15, the Mail app could also have something wrong occasionally, such as Mail app unable to receive new emails, password incorrect, Mail app blank screen. If such mail problems, please take the steps below:
iPhone Mail Problems
1. Mail App Cannot Receive New Emails and Say Password is Incorrect
Step 1. Open Settings app > Choose Mails.
Step 2. Tap Accounts > Choose the account that has issues > Scroll down and select Sign Out.
Step 3. Go back to Accounts list > Tap Add Account to add your email account.
2. Open Mail App and Find a Blank Screen
Solution 1: Remove the account that has issues and adds another email account.
Solution 2: Delete some old emails. Go to your mail account on a computer, and then delete the messages that are over 6 MB or any “mail deliver failure” messages. Also, delete and then re-add the account on iPhone/iPad.
Solution 3: Restart your device. To do this, you can press and hold down the on/off button and the Home button until the device restart with the Apple logo.
There is a strong possibility that after upgrading to iOS 15, your iDevice becomes very slow, laggy, or even sometimes screen freezing and unresponsive. This could be because of much updating data saved on iPhone iPad, or some other factors. So you can try some professional iOS cleaning software, like PhoneClean, to remove the useless data, or follow this guide of ours to learn more about how to speed up your iPhone iPad after iOS upgrading >
iPhone Slowing Down
These days, life without social network cannot be imagined, especially the popular Facebook. But according to the feedback from iOS 15 users, sometimes the Facebook manager will become unresponsive on iPhone. If you are looking for methods for this Facebook Manager problem, you can get it working again with these tips:
Tip 1. Restart Facebook Messenger.
Tip 2. Is your Facebook app up to date? If not, upgrade it.
Tip 3. Re-install Facebook Manager.
Tip 4. Restart iPhone iPad.
After iOS 15 upgrading, you may encounter various screen recording nor working issues: recording videos can’t save, recording videos no sound, and screen recorder crashes, etc. Try the steps below to fix them all:
Step 1. Make sure Screen Recording is enabled.
Step 2. Reopen Screen Recording and restart the iOS device.
Step 3. Reset all settings.
Surely, a topic page is also prepared for details about how to fix iOS 15 screen recording not working >
On iOS 15, you probably will receive such a message, when launching some app on your iPhone: XXX Needs to Be Updated. The developer of this app needs to update it to work with iOS 15 or XXX Needs to Be Updated. This app will not work with iOS 15. The developer of this app needs to update it for compatibility. This is actually because of Apple’s new app policy: iOS 15 only work with 64-bits app, while 32-bits not anymore. You can refer to this guide for more information about it: such as what is 32-bits app, how to fix it, how to check if it is 32-bits app, etc.
App Needs to Be Updated
Everything You Need to Know about 32-bits App >
After updating to the new iOS version, when you try to restore from iTunes backup on your computer, you may have got a message saying, “An unknown error occurred”. Or after connecting your iPhone to iTunes, you cannot find an iPhone icon on the iTunes interface. That makes you can’t restore your iPhone/iPad from backup. To fix this error, you can follow this guide about how to fix iPhone iPad won’t restore >
Obviously, this post has not covered all iOS 15 problems, and all these titles above are just iOS 15 problems so far, collected from users’ feedback. So if you – are great users have found some others, you can leave them in the comments, and we will update them in this guide with fixes as soon as possible for you. Besides, losing data when upgrading to iOS 15 is also a very common problem, if you get into this trouble, you can directly go to this guide for answers: How to Fix “iPhone iPad Data Lost/Disappeared” After iOS Update >
